Rollcage install
StrokedEJ
I had the option of 6 or 8 and seems like that still since 2013 changes.
Forward to strut towers optional but adds a lot of strength to chassis for handling
http://manual.motorsport.org.nz/index.php/knowledgebase/36-2-01b-schedule-a-2/#a2-5 Motorsport nz standards.
the thing is changing and extending a half cage to full gets hard to weld all the bars together 360 degrees around and may result in the roof coming off and coupes the rear glass as well
you can offset the weight by removing the factory side intrusions etc.
I believe the cage needs to extend to the front strut towers if you have removed the airbags and you want this included on the authority card.
The LVVTA cert can cover the removal of the airbags if the car is pre-2001, however it's generally much easier dealing with the authority card scrutineer than the LVVTA cert guy. Plus as Gripless said, it also improves chassis stiffness which is worthwhile in a GC8.
