Pappu1
Replacement Wideband sensor for AEM UEGO kit
any well priced locations where i can ge Replacement Wideband sensor for AEM UEGO kit
think they are the Bosch LSU 4.7  .. i think...
Share this post
Link to post
10 minutes ago, Andy_Mac said:
Is 4.7 even a thing? Thought they went from 4.2 to 4.9?
typo 4.9 i mean oops sorry..
Share this post
Link to post
What do you consider well priced? I've got a brand new Bosch 0258017025 LSU 4.9 sitting here if you need one in a pinch. $135
Otherwise something like this might be the treat https://www.amazon.com/Replacement-Replaces-0258017025-Compatible-Wideband/dp/B07L2S3JRG/ref=sr_1_4?keywords=Bosch+0258017025&qid=1551315909&s=gateway&sr=8-4
Share this post
Link to post
do the "replacement" sensors work any good (worth the monies?
the AEM leaflet says does not need free air cal but is it worth a try at all?
mine reads ultra lean and then spikes rich and normal for a second then back to lean
Share this post
Link to post
No idea, i've never had to replace mine from the original that came with my AEM wideband.. but its the same part number as the one I got when I thought mine was dead. Bosch 0258017025
Share this post
Link to post
 how did you fix ypur "dead" unit?
what were thye symptoms
im hoping i can sort mine as well
Share this post
Link to post
@Pappu1 Mine would go super lean and then creep rich over the period of about a minute after turning the ignition on. Turned out to be a bad earth.. the ground wire had come out of the plug.
Share this post
Link to post
i will check it out
mine does the exact same thing
stays super lean and then occasion would show rich
and on the odd occasion shows fine on idle
Share this post
Link to post
just inspect the plug on the sensor real good. sometimes you cant tell if the wire has broken off the pin cause its all waterproofed under the rubber grommets etc aem-30-4110-sensor-connector-kit.png
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
