Gripless
Project Kinder Surprise - engine build
What is this project?
Its an engine build with a discussion and details about options and trade offs building an engine. Hopefully heaps of photos and video.
Why?
Because I couldn’t find the details I wanted online in one place and heaps of builds leave out the discussion on why they picked the parts and what flow on effects it makes.
Plus after @Joker posted about Facebook YouTube take over I saw a motor and it seemed like a good idea at the time.
Whats with the name?
It came for a PM from @PBMS as the base engine for this is a EJ207 W block with a suspected cracked piston that on one has looked at yet. Until it’s opened there’s no idea on what’s inside.
When does it start?
It started on just now March 2019.
Where is it?
it will be in this topic mostly and across Possum Borne MS YouTube etc.
How long?
over the next few months
since the engine is a donor the cars stays on the road.
Whats the plan?
So far it is mostly pending the inspection of the block.
Initial thoughts are:
- build it for around 600hp and then street it about 450whp.
- Stay 2.0 as the cost of stroking it are a lot higher. As long as the crank is still good.
- CNC the heads
- Cams around 264 but has dual AVCS so maybe bigger
- close deck maybe depends on block condition
Since this is my first Subaru build this topic  will be pretty open to ideas and the plan will form.
Edited by Gripless
  • Like 4
Share this post
Link to post
I googled project kinder surprise and it came up with weird things in eggs.lol.
Where is it ?
Share this post
Link to post
The details will appear here and across YouTube and I’m guessing Facebook.
I was going to add more in extra posts but needed to wait for a bit or it merges them all into one.
So far the engine has been purchased and picked up.
The engine should come with everything including twin scroll headers and stock sti turbo. Plus some extras like a baffled sump and a twisted turbo adaptor.
So there will be a heap of stock parts to sell off.
Share this post
Link to post
Interesting parts from Crawford who built the Subaru gymkhana cars.
http://www.superstreetonline.com/how-to/engine/impp-1103-subaru-ej-series-engine-tech/
Aftermarket water pump with a cast turbine that flows more water, whereas the OEM piece allows for water to bypass the blades and does not flow as much water.
Ok was going to replace anyway so will check what type the replacement is.
Another falsified fact is using a lower-temp thermostat will make your motor run cooler in hot weather but in reality it will have zero effect on increasing your engine's cooling capability.
Wasn’t considering this and won’t likely add it now.
People believe larger pressure/volume oil pumps are always better because the factory oiling system on the EJ motors are inadequate, when in fact, a high-pressure oil pump can cause oil cavitation while lowering the ability for any oiling system to work efficiently.
Heard this one a lot already.
Other falsified facts include tuners believing that installing 1mm oversized intake and/or exhaust valves over the stock size valve seats will increase cfm airflow
Ok that’s take that off the list. Plus I suspect it was going to add cost to pistons
and the best of all that makes me laugh every time I hear it is "you can make 500 whp safely on pump gas."
Hopefully this is American were gas is crap and more like 91.
For really high-horsepower applications, pinning the mains and oversized head studs and/or an O-ringed cylinder head may become necessary.”
Don’t think I’ll be getting to this point but depends on price.
Share this post
Link to post
Join HP Academy if you want to build your engine properly or get a better understanding of how a performance/race engine should be built.Excellent modules take you through preparation,measuring,machining,clearances,balancing,blueprinting and assembly.
Share this post
Link to post
Not specically for this build, but always good to watch
The grandfather of turbo charging Gale Banks
Share this post
Link to post
Surprise 1
So the engine has been torn down.
Results are good. Engine looks better than expected B|
No evidence of cracked piston or low compression that resulted in the engine removal and sale.
So a set of STi rods and pistons will be for sale soon.
Now the hard question
Should I sell the mint 2L crank and get a 2.5L crank or not?
The idea of a 2.2L has its appeal for obvious reasons GR-22-B
Edited by Gripless
  • Like 5
Share this post
Link to post
Update
Today...
talked to Kelford
Sounds like the 220-B are the cams to go for if sub 600hp but bordering on the 220-c.
Dual AVCS make them very street friendly.
They have valve guides and seals along with spring option all available
And Horsepower heads
agreed with fully ported heads the 220-B cams will support huge power.
The exhaust port will be exiting at 40mm so need to address the headers size as likely only 32 or 36mm
this maybe within the ability to stretch the factory headers to smooth the exit.
The dog leg port will flow close enough to the straight one to make no practical difference.
No change to the intake port outer shape so the TVG and manifold won’t need any work above the deletes and tidy up.
the factory valve guides aren’t exactly great. But the ones in the new engine are worn so need replacement anyway.
Inconel valves for exhaust are a recommended option to handle the high heat.
And an email from PBMS
looks like valve springs and billet crank are the best option for striker and keeping the current 8500rpm redline. Need to go have a proper chat about the range of options.
Edited by Gripless
  • Like 5
Share this post
Link to post
This morning
Picked up the spare parts
- Worlds worst wastegate. Greasy mess with poor seals and shiny blue top.
- Vf49 stock turbo. Looks ok and no in/out play but told it not in good condition. May get it looked at later.
- Stock STi headers which are 39mm so almost perfect for 40mm head work that’s coming. I have a set already so can just grind the existing ones a little and keep the ceramic coating intact.
- Twinscroll up pipe
- Twinscroll up pipe wastegate and twisted adaptor. Have to unbolt it and check it out.
- Stock STi pistons std and just look dirty
- Stock STi rods clean and tidy
- Stock STi 75mm crank measures up std
- Stock dual AVCS STi cams
- Stock valve springs and retainers
- 6 Speed flywheel
There is more like a clutch and the air pump valves and baffled sump that may be reused.
Plus
Grabbed the TVG and intake manifold castings so I can grind them to flow more.
Share this post
Link to post
8 minutes ago, Andy_Mac said:
Did it have a twisted adaptor for the stock turbo?
Yes, yes it did :o
No idea if it was running like that on the car but that’s what I got.
Share this post
Link to post
Update
Sounds like 13-14mm head studs are not worth the effort and haven’t been solving any gasket issues. So they are out and the 625 11mm ARP studs are about the best option so they should be on the list.
Current plan is for:
79mm billet crank stroker to 2.13L
latest JE pistons that are coated and gas ported
Some rods to match
Random other things:
Seems the W motorsports block won’t even need closed decking for 600hp. So that is on the fence as the crank adds so much cost.
Head gaskets need to be figured out as there are so newer options with copper “fire” rings that may help.
Turbo is still a mystery option interested to hear what people think?
Looks like it will have to be rotated or low mounted so it can be big enough to make power.
Also if any one has a parts list for all the seals etc you need for a rebuild that would be awesome...
Share this post
Link to post
I'll be going for the Athena HG (fire ring) when I fit my dual avcs heads.
Turbo - I've always said if I was going for a completely new set up I'd go EFR as they have inbuilt WG & BOV so save the extra cost. With that in mind, they have the turbine wheel failure issue (especially on the smaller turbos which i'd be looking at) so need a speed sensor and some ecu smarts so it can't over speed.
Partsouq has a complete engine seal kit which could be worth looking into. When looking for the seals I need for the head swap I went onto ebay and found the "head gasket kits" which listed all the required parts, grabbed parts that suited. Someone on ebay might have a rebuild seal kit that you could copy.
Share this post
Link to post
 Thanks for this...
I’d seen those Athena ones and they looked good and about the only 2.0L ones.
Ok so these are just JE Pro Seal gaskets and sizes are limited.
http://www.jeproseal.com/sport_compact.html
ebay only has the intake AVCS ones.
Will have to try Subaru NZ to see if they are helpful.
EFR looked nice but I’d block the BOV and run the GFB one still I think.
Edited by Gripless
Share this post
Link to post
So other than figuring out all the extras like injectors belts and bolts cost add up fast.
Still not sure what the difference between $1000 and $600 injectors are when the are both the same cc and Bosch or denso.
I started to clean up the intake manifold and discovered there are large casting marks just around the last bend for #4.
Not just normal seam castings but a 1-2mm raises 10mm diameter circle.
Carbides and sanding pads don’t reach.
#2 also has one but it not right on the start of the curve.
Also it looks like since the #4 runner is so low and flat it gets to collect the most oil that gets into the intake.
The manifold is also 4mm smaller diameter than the TVG’s so much more grinding to do.
Just have to make sure it’s all lined up.
Share this post
Link to post
What intake manifold are you using? Flipped?
Have you looked at the n/a short and longer runner manifolds (best factory flowing).
Share this post
Link to post
So, heres a bit of information that I'm aware of in regards to injectors.
Injector Dynamics command a much heftier price because of the following:
All your injectors are matched to very close similar specs. For example, my set of ID1300x2's all flow 1331cc each. Meanwhile a factory set of bosch or potentially other companies may vary by a few cc to 10 or 20. Depends on their quality control and matching.
ID use proprietary internals and nozzles for their injectors (at least going off their videos and marketing guff), which they claim is superior.
The likes of FIC etc may have different processes but from my understanding their matching and nozzles and internals of the injectors while aren't bad, are more in lines of the factory item they're modified from. So matching might not be as close as what you'd get from ID.
Share this post
Link to post
Haven't researched it myself, but would be awesome to see some actual results based comparisons aye. ID stuff is sooooooooooooooo expensive.
Share this post
Link to post
My understanding was they brought in bulk then just matched them up into smaller sets. Some companies do flow others flow and dead time.
Other thing is the factory plug is denso so that would save having an adaptor cable added to the mix.
ID also use fancy alloy extension but others are plastic like the injector
Share this post
Link to post
Fuel Injector Clinic FIC has 1200cc injectors that are all 1-2% matched sets.
450whp E85
650whp pump gas
USD$540
They say idle and street driving is fine until you go past the 1650cc set which does.
580whp E85
780whp pump gas
USD$840
Bonus they have spreadsheets for the stock ecu for reflashing.
http://fuelinjectorclinic.com/wrx-stilate
How they match sets
Edited by Gripless
Share this post
Link to post
While looking for more details on the stock manifold to see if there are any good things to do found these bits:
Just porting the last section before the TVG section gives at least 5% flow gain at the valve opening on a flow bench. This could be more with the CNC head porting.
There are place that port port the throttle body 2mm to 62mm and cut the rod in half to increase flow.
I’m keen to cut most of the bar out and smooth the opening out. But the opening depends on the final intake pipe. No point making the mouth bigger than the pipe leading in.
ive done this before on NA cars for good gains from 60mm to 63mm with half the bar cut away.
Plus I messed up a long handled spoon to make it reach around the manifold bends to sand off the bumps.
Share this post
Link to post
After getting costing and mapping turbo spool and flow it seems the stroker is almost pointless and costs an additional $3200. Plus reduces the redline potential so it seems the engine is 2.0L again.
Heads should be heading down to horsepower heads for the CNC next/this week. With new bronze magnesium guides fitted since they will be removed for porting and the current ones are a bit worn.
If I get some time I’ll get video of the before and then some after.
On the valve front if there is any Easter sales 1mm oversized valves may find the way in. These are needed but since most places don’t stock or sell the stock size inconel exhaust or undercut stems intake.
Tomei have a full set and some of their stuff is just cosworth built.
JE newest Ultra pistons have been ordered.
Share this post
Link to post
Still have to pick valve springs as the titanium retainers I have work with most springs.  Manley seem to be the cheapest and good to 10k rpm limit.
Thinking that the buckets must add more weight to the Subaru valve train.
Have to add new valve keepers as well so adds $100usd more.
Cobb map sensor looks to be plug and play so can hit the 30-32 psi planned boost limit.
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
  • Similar Content
    • By swamp
      Hi all
      I am a noob and do want to replace my (broken) factory bov with one such as a hks ssqv or V6 sti I believe it's an HKS unit.
      However the problem is that my turbo inlet which is on the early wrxs uses a hose rather than a flange to the turbo-intercooler pipe. I don't run the factory pipe rather I use radiator/silicon Hose as mine broke. To fix this, would I either have to get some silicon Hose, drill a hole to fit flange? Or is it best to buy a factory hose?
    • By greasemonkney
      new here,
      but wandering if anyone knows a decent place to either get a angine refurbished or where to get a standard refurb kit for a ej203 for a 2003 bp5 liberty wagon.
      it currently has 380xxx kms on the clock and is showing its ware and tear. just wanna refurb for now and turbo convert later next year if i can swing it. my baby girl is gonna get some love and care as the last owner didnt maintain her at all
    • By Shibe
      Sorry if this has already been a thread before,
      but i recently got picked up an 07' Impreza S-GT, 2.0 Turbo 5 Speed. Excellent car and I'm having a blast driving it.
      Anyway, the car has just under 170000 k's and I believe it's time for me to do a service - oil, filter, etc.
      What are some other things you guys generally do when servicing your turbo Subaru's? I was having a gander at servicing videos and the general service seemed to include cleaning the AFM, resetting the ECU, and top engine cleaning? I feel like some of it is a bit unnecessary but and pointers are greatly appreciated. I feel and oil and filter change would be sufficient enough?
