• Announcements
    • 1randomkiwi
      ClubSub Forum Updates   13/03/19
      Important forum upgrades are coming up which may mean the www.ClubSUB.org.nz forums will be temporarily unavailable.   Check out our Official Facebook Page for more updates.   www.facebook.com/ClubSubNZ
revoltingasp
05 V9 WRX STi peaking 22PSI
16 posts in this topic
Hey guys! I’m the second owner of an immaculate  Japa Import 05 wrx sti. I bought the car a year ago with 39,000 original K’s on the clock hence why I’m always worrying about it😂. Long story short, I bought this car off of a 75 year old in CHCH he had put a “RAGE” exhaust on the car. Took her to the local Subaru dealership today for a service and the head mechanic told me that I’ve got an aftermarket cattless downpipe hence why my heatshield for my turbo is gone and this is probably the cause for the 22psi peak However in third gear if I WOT between 3.5-4k rpm it shoots upto 19PSI and holds there as if my car is really pushing 19 PSI. The car is now on 55,000k’s I get it serviced every 5,000k’s, check oil and coolant every Friday. And I can literally count the amount of times I’ve boosted first gear, she’s never been launched and I always wait till she’s warm before going over 3k rpm. Is this high boost level anything to worry about? Or should I get it tuned either to support the 19PSI or to lower the PSI to make sure she’s running safe. Just want what’s best for my subie 😊 TIA
Edited by revoltingasp
1 person likes this
Share this post
Link to post
Get it on a dyno with a wide band o2 hooked up and see what the tune is really like.
Then make a plan when you know what’s happening.
Could have been tuned when the exhaust was done.
6 people like this
Share this post
Link to post
Hey man. Yeah will do, dude at Subaru said most likely there is a tune done however I have no way of finding out who did it and when. Possum Bourne quoted $1200 for tune and dyno :/
Share this post
Link to post
Most places will do a o2 monitored dyno run for less than $200. It obviously doesn't lessen the cost of a tune if you do need one but it'll let you know straight away how the current tune is and whether it needs a re-tune or not.
1 person likes this
Share this post
Link to post
Where is the the 22psi peak? You said in 3rd it just goes to 19psi and holds... which will be fine.
2 people like this
Share this post
Link to post
Hey man, yeah It holds at 19 however when I hold the peak warning it flashes at 22 psi and when I first got the boost gauge the peak warning was 19 so sometime it must’ve gone to 22? I have no idea how. I spoke to last owner and he didn’t get a tune done with the new exhaust :/ so a bit lost now!
Hey man. Spoke to the last owner he told me he didn’t get a tune done but the catless downpipes look to be professionally done. A bit lost now as I will probably have to get it tuned to support the high psi? Which = more damage on internals because of higher PSI? Or I’ll have to lower the power and get the exhaust re done to lower the PSI? Either way I think I’ll need a tune.
Share this post
Link to post
As long as you're running it on 98 it's not going to do anything bad.
I have a V7 STI which only has arguably marginally stronger internals and I've run something like 26psi from a WAY bigger turbo through it and it didn't die.
I ran it (untuned) for like 2 years with a downpipe and exhaust and it was hitting something around 21-22psi all the time and it didn't give a damn. Just run good fuel, don't thrash it when it's cold, and factor in getting a tune somewhere down the track - budget $1500 and get a high-flow panel filter, a 3-port boost solenoid and an aftermarket fuel pump just for good luck, car will probably make a safe-as-houses 215wkw and drive bloody nicely too.
4 people like this
Share this post
Link to post
wait what???
6 people like this
Share this post
Link to post
If you are wanting to play it extra safe (which is what I'd be doing) then go and speak to the tuner and see if they will book a dyno slot for you, but if the initial baseline test looks good and you are happy with it, agree beforehand that you have the option to stop there and only pay $x i.e 2-3-400.
A decent chunk of the work of getting it tuned is setting it up on the dyno, checking everything is working fine etc.
PBMS are a good bet I should think, personally I used E&H motors to tune my standalone ECU and I'm very happy with the results. Karl Ruiterman has a lot of experience with subarus and used to be the only option in Pukekohe until PBMS got back into tuning.
2 people like this
Share this post
Link to post
Ight cheers man, yeah I always run it on 98 and I only go above 3k rpm when it’s at normal operating temp. I play it really safe all the time :)
Alright thanks heaps bro! I’ll def look into a tune. Just want my car to be running as healthy as she can hahaha. Cheers again dude
Share this post
Link to post
+1 for getting it tuned,
My old version 8 when i bought it did exactly the same. Had an exhaust but no tune and it constantly overboosted.
As @boon said, new panel filter, 3-port, fuel pump for good measure and proper dyno tune. Car will be a street animal. Sure @PBMS will be able to do something for you if you say you're from clubsub and do the lot with them :)
Edited by Niran
3 people like this
Share this post
Link to post
You can also try An Lal from custom culture and tuning he's done a few of my cars and he's very thorough, and results always good He has roadtune and dyno option. Roadtune much cheaper. Not sure if he is still active here but search it on facebook.
3 people like this
Share this post
Link to post
Cheers man, that’s so much! I’ll def look into the tune. The cars fully stock and only has 50,000k’s on the clock. I just put the second Set of tyres from the factory that’s how untouched it is 😂 I really want to make it quicker but at the same time I want to keep it fully stock because it’s such a good exemplar of s sti
4 people like this
Share this post
Link to post
yeh hes here as @Pappu1
3 people like this
Share this post
Link to post
hey man, 19psi is ok for a tuned v9 to hold
usually drops in the higher revs ..
with catless exhauts, they do spike a bit and normally its the spike that could be the issue ..
either way, with a good tune, they get safer and can run that boost well..
will pm u..
is your one a black v9sti?
surprisingly, we just tuned 2 black V9's in the last few weeks with similar setups...
1 person likes this
Share this post
Link to post
will pm u..
Hey man! Sorry for late response. Nah mines silver, I’m gettint a fam friend to do a dyno check on it to see if it’s running mint. Then I can see where to go from there :)
Share this post
Link to post
