• Announcements
    • 1randomkiwi
      ClubSub Forum Updates   13/03/19
      Important forum upgrades are coming up which may mean the www.ClubSUB.org.nz forums will be temporarily unavailable.   Check out our Official Facebook Page for more updates.   www.facebook.com/ClubSubNZ
Aptenodytes
Outback 3.0 - can it TOW 2 tonne tandem trailer?
13 posts in this topic
Hi there,
I live in Nelson, take a tandem trailer with a 6.2m aluminium hardtop boat (total about 2 tonnes) to Havelock perhaps 5 times / year (it's 80km of winding, hilly road). I swap cars with my brother and use his 3.6l Commodore VE for boat towing (we share a family bach and boat) as my 1995 Legacy 250T would not have been up to the job. However my Legacy got a death sentence at the WOF last week (RIP :( ) so I'm in the market for a replacement. It would make sense to get a car that can tow the boat.
I would like to get a 4th Gen Outback 3.0R (2004 - 2007 or so) and have spent some time trying to work out if it would be up the task of towing 2 tonnes. I've found plenty of information in this forum (thanks!) and elsewhere on towing with 3.0 Outbacks, but nothing definitive.
- Tow rating for this car would be 1800kg braked (750kg unbraked).
- Some suggest an additional trans oil cooler would be needed (some suggest it would be difficult to fit).
I've read a few lists of good towing vehicles on horse float / boating sites and nobody has mentioned any Subaru for towing, not even once. They usually mention the standard big SUVs and also Falcon/Commodore etc. My gutfeel is that 2 tonnes is a little too much for an Outback based on kerb weight etc and the transmission / drivetrain would be worked a bit harder than it should be.
So what does everyone think? My guess is if I said Hilux / Commodore everyone would say "yes", if I said 2.5 Legacy everyone would say "no' but if I said 3.0 Outback it's probably in that slightly worrying ground in between.
1 person likes this
Share this post
Link to post
One of my friends brought a 3.0 legacy to tow a horse float and horse, it was just under the limit for weight but wishes she got something with a bit more power.
Personally if it's going anywhere near hills don't get it.
1 person likes this
Share this post
Link to post
Gret Subaru Road!
Ooh Part of me would say yep, is it braked? if not don't bother, but who would have a boat trailer that size unbraked LOL
then again part of me would say no, be a bit iffy so LMGTFY
https://www.aa.co.nz/cars/owning-a-car/towing/towing-weights/subaru/
says 1600 & 1800 kg max on Braked 3.0's (Outback & Legacy)
what does your tow bar say? (Some are S*** / cheap & simply not up to it) I've ripped the bum out of my floor once on a trip back from Napier in my GTB
I liked the "sure footedness of the GTB for towing the Race car, both on Manual gear box & brakes but use a Commydore now too...
Share this post
Link to post
A customer of the shop I used to work at had a 10 3.6 Outback with the 5 speed auto. Towed her Horsefloat pretty well from what she said.
Had it in the shop cos the electric brakes on the float were screwing up.
I'd say you'd be ok with using it as a tow vehicle. But personally, something with a 3L diesel would better - say a Toyota ute/SUV with a 1KD-FTV diesel will be far better.
Edited by Individualities
2 people like this
Share this post
Link to post
Windy, hilly roads are the biggest test on towing ability. Even when braked it doesn't take much for a trailer heavier than the car to start determining the direction you take rather than yourself which won't end positively.
In the city driving to the local boat ramp we’d probably all say you’ll be right but it’ll be a struggle on narrow winding roads and you'll more than likely piss off everyone else on the road as you cautiously make the trek.
2 people like this
Share this post
Link to post
We have a 6m glass boat on a tandem axle braked trailer.
We towed it from Auckland to Christchurch down the alternate route while kaikoura was blocked and through the Lindis pass. This was using our 2.5T auto 2008 SH5 Forester.
Under brakes it is good and never have had a brake fade issue or felt uncomfortable under brakes.
However... if the coolant system isn't up to scratch you will suffer. Our radiator was blocked and this caused us overheating issues so I'd get the radiator rodded or replaced, rodding a rad is cheap.
I would also consider a trans cooler and eventually I'll fit an oil temp sensor to the engine oil.
Suspension wise the factory suspension has a tendency to pitch a lot, this is amplified while towing and is not stable, ie the oscillation gets bigger as you go faster. We can safely tow at 90kmh but around 100 kmh the oscillation starts and gets a bit scary. Not a big issue but worth noting, this is likely to be different to an outback.
I don't believe the pitching is a tongue weight issue, we are around 50kg tongue weight.
Sent from my SM-G960F using Tapatalk
1 person likes this
Share this post
Link to post
Have towed for many years a race car on tandem trailer with spares and fuel. Yes there is better cars but we have done kilmogs, arthers pass plus all the way to whangarei. The old outback does ok just keep eye on Temps and keep servicing up. It is extremely thirsty when towing though
1 person likes this
Share this post
Link to post
We see ~18l/100km when towing on the open road at 90km/hr
Share this post
Link to post
Thanks for all the comments. :) Looks like everyone is more or less on the same page here, for towing two tonnes I really should be using something a bit bigger / longer / heavier / gruntier etc. I've decided I won't be towing the boat with a Soob, I'll stick to borrowing my brother's Commodore (they're fine with it).
So now I'm in the market for an Outback or Legacy wagon (probably 2004 - 2009) and either 2.5 or 3.0. I'll still have a towbar fitted but won't be towing two tonnes with it. Joker, the car sales yards down here (Nelson) tend to quote about $600 for towbar fitting, I think it's all done properly according to manufacturers specs. I would hope that that price would get me a decent one.
1 person likes this
Share this post
Link to post
BTW towing the boat (tandem trailer, about 2 tonnes total) with a 3.6L VE Commodore gets about 16L/100km on the winding, hilly Nelson-Havelock route at a guess, doing 90km/h on the straights. It feels pretty safe and solid to me, no yaw or pitch at all. Never had to stop in a hurry though, hope I never do... My brother prefers towing the boat with his work Hilux 3.0D twin cab manual ute though, even though it's much lower powered than the Commodore it's got all that low-down torque.
1 person likes this
Share this post
Link to post
Ive had a pre facelift 2.5 outback and now have a facelift 3.0.
Go for the later models in 3.0 is my opinion, I find its a little bit thirstier when just doing a lot of short runs, but evens out wih a few longer runs.
Also if going auto the 3.0 has the 5 speed.
Both are great wagons, but prefer the 3.0.
1 person likes this
Share this post
Link to post
I have a 3.0 Outback facelift and agree with poor fuel consumption.I normally use the white Subaru oem filter but replaced the air filter with the orange type,noticeable improvement in fuel consumption.Run Mobil 98 from the same local gas station.
Edited by Dre
Share this post
Link to post
In a pinch you would be fine. Another bloke on here used to routinely tow his racecar on a tandem trailer all over the place with one. Eventually the trans shat the bed which was somewhat to be expected.
2 people like this
Share this post
Link to post
  • Similar Content
    • By swamp
      Hey lads
      I'm thinking of setting up a trailer plug when I do get my tow bar, is it simple enough to do? I'm yet to look at a wiring diagram but I'm guessing I'd have to find the power and ground of the stop and indicators and simply splice into them. Can anyone confirm?
    • By Hinkie
      Hi Subagurus
      Inspired by Super Guitar Guy  and Super Stereo Installer I thought I'd share some information in appreciation of the super time and work these guys and everyone else generously shares here, thank you.
      I've decided to do the double DIN and install one of the new Kenwood DNX9180DABS HU with Navi and add the dashcam. Currently collecting my bits, plans, work in progress. I figure if I can get all that kit running my Outback will be more capable than a new one, (no dashcam!) and a hell of a lot cheaper! Plan is to use the existing amp. I think they feed 80W (RMS?) per channel but that's not confirmed. Still knowing how they perform I am happy enough with the McIntosh amp and speakers.
      In the mean time I wanted to swap the Japanese banded PF-4062l head unit with an (ex NZ GT Legacy) PF-2551l for the standard NZ bands.  Thought must be too easy!
      Wrong!
      Swapping the units, which have the same plugs (not necessarily the same wires though!) proved to make both the McIntosh display and the upper Nav screen (Still in Japanese) just flash and will not work....  Quickly turn off....
      After much thought and studying most of the Internet and with a little help from Jeremy I figured that the 4062 will have, being a later unit, a lot of stuff that integrates with the Jap Nav gear, and that it all connects through the 20 pin J800 socket that has a heap of wires that I've not traced, but they connect to the Bus, what ever smarts are therein, no doubt the intermediate SWC smarts (not found how Subaru interface the control with the HU, but probably academic) and the Nav and who knows what else. The more common Subaru 20 pin plug J901 just has the power lights and antenna amp power - all essential to run the Head Unit.
      So....Legacy PF-2551l will run fine in a JDM Outback as an interim radio for me. Woot. (without steering wheel controls connected) when one simply does not plug in the back J800 plug - for anyone wanting to try that. Will keep me going for now.
      For the planned Double Din install I've bought a "junk" PF-4062l from Croooober for its sockets, especially the 20pin DIN wired female socket. My original thought was to use all the sockets as that would smooth the interconnection, now that expectation I've now pretty much shown to probably be wrong so arguably it was an expensive 20pin DIN, but then seems they're not otherwise available at any price.... Part of the cost! For anyone wanting to also do this conversion I figure a junked EF-1208l amp could also be used as a 20pin DIN socket part source for the HU end to run to the Mac amp being used in the car. That would have been cheaper for me, but committed now. There's currently a cheap one going to the first taker....
      I bought some RCA leads which I'll splice into the newly imported DIN plug lead at HU end which I figure will be robust enough. Also will need to feed the amp on (I assume) with the +12V "Power on" to turn the amp on. Plan to find the Original Subaru GPS existing device and swap it with the new Kenwood one. Seems no point installing the digital antenna on the windscreen as I think (open to correction) there is no digital audio around to connect to in New Zealand, especially the Wellington region. Yet to resolve issues anticipated. The McIntosh kitted 'rus feature 4 speakers in each front door. The Kenwood has some rel sophisticated frequency smarts for feeding different speakers different frequencies, particularly to protect tweeters. But they don't go so far as 4 different speakers per front channel with intermediate single feeding amp channels(!). I don't know but expect there is a crossover network in each front door (anyone know?) which'll do the frequency distribution just fine. So that leaves me with the expected question of what cut off frequency to feed the sub woofer, and whether I trim any base of the four door channels. It might all just work without fiddling with any EQ. Not yet figured out what to do with the Nav unit, expect the Backing CAM works and is appreciated, all be it at a liney resolution. Be nice to have a 720p front and rear cameras with the front one thru a replacement 720p screen mounted between the vents, and the higher defn rear cam thru the Kenwood. Not figured that bit out. Comments welcomed.
    • By dumbskate
      Hi All,
      Its a been a few year since posting here but I've happily been through three more Subaru's since then.
      I now looking to update the family wagon from our '04 Legacy to a 3.6R premium '10 or '11 Outback but I don't want the leather seats that seems the option ticked by ever original buyer. So if anyone out there is keen to swap for their tidy non-leather seats then sing out. I haven't settled on a car to buy yet but am pretty sure what I want will come with black electric leather seats.
