Overheating gremlins!
swamp
Hey guys
I'm still having overheating issues. I initially fixed up my car so I could drive it when I moved halfway across the North island. It drove fine on the open road with the temp gauge slightly below halfway.  No issues to speak of for a while.. Recently however I've noticed that temp gauge will heat up and get 2/3 or so of the way up as I drive round town.. I have kept an eye on the overflow and tank levels.
Today it made its way right up but 30m down the road went back down to 2/3. Removed radiator cap and no steam or boiling. In the morning it got hot too, and it was 5deg out.
At home checked if fans were turning on and nope, they didn't. But just ran it for 30sec..
I'm not sure what it could be. I bled the system following a tried and true method on the forum, replaced radiator cap, flushed radiator, replaced faulty thermostat with new OEM unit..
44 minutes ago, TNHSTI said:
I hate to say it but I'm thinking head gasket is on the way out a legacy gt I had did the same symptoms
Shàll I just change them before they blow then? I'm about 8000kms away from a timing belt change so can do it all in one hit.
No water/oil mixing to speak of yet.
Edited by swamp
If it was my car I would but that's just me
Yeah I will.. I'm guessing it's cheaper when your heads aren't warped. Just missus van leaks water from two split hoses which I'm waiting on so I dont have to punish my HGs.
