Gripless
Water to air intercoolers
Anyone seen https://frozenboost.com  range of gear?
about $450 plus shipping gets 600hp setup with heat exchanger, radiator, pump and remote cap. Just need to add lines.
Share this post
Link to post
Yea, they have some serious heat soak problems though. I came bloody close to going that route myself. Would love to see someone in NZ do one on a big power Subaru.
A few Aussie Liberty guys have gone that route. Makes even more sense on big power Legacy’s/Liberty’s since the space for an intercooler is even smaller than the later STI’s.
One guy had a heavily customised setup on an engine pushing 330wkw. Still running it on his new 2.7 stroker but haven't seen the latest dyno plot.
The standard pumps arent reliable enough so most like to upgrade to the cobra option.
Share this post
Link to post
heard mixed stories on the heat soak on these. bmw use as stock on some of their M cars and claim less heat soak, but haven't seen any logs myself.
Share this post
Link to post
That was with cobra pump not the nasty plastic thing.
Only thing that that I don’t like is that if they leak into the intake it’s pretty much a horror story for the motor.
I cant see how they can heat soak. Water is something like 25x more efficient at conducting heat. As long as you don’t over speed the water flow it should draw heat extremely well, plus since the cooler is out front and you’d have to heat all the water before it loses efficiency
Share this post
Link to post
Solely because the specific heat capacity of water is so high. While it has the ability to pull a crap tonne more energy out of the charge air it also takes a crap tonne more air to pull that energy back out of the water which the radiator fans won't do very well when stationary.
Once they do get hot it is super hard to cool them back down unless doing consistent high speed or the ambient temps are very low.
On the track they’ll be ok but stuff like autox they'll be absolutely rubbish.
Getting the ice box and using that between runs may help that issue though.
Share this post
Link to post
That is kind of true but the area differences between the exchanger and radiator offset that quite a bit.
I cant find much that says they heat soak from people who actually have them. Other than drag racing but they are icebox only.
Share this post
Link to post
could always do what they do with the hellcat and run ur ac through it when heatsoaked or something 😜
Share this post
Link to post
F*** that was awhile ago,10 years ago ? maybe, dude was a dickhead
Share this post
Link to post
Looking at current vehicles heaps or euros and even the American F150 run water intercoolering now.
Share this post
Link to post
It's a tidy way for OEM manufacturers to run setups that fits the power and cooling envelope they require and they have the ability to change anything else they require to ensure it all works as it should.
Especially with twin turbo V8 setups that'd otherwise clutter the engine bays even further.
I'd only be comparing to other aftermarket examples to justify this route to be honest.
There’s a bit of a discussion from a few years back on legacygt.com
That guy is the one who develops/sells all the auto trans mechanical improvements to handle decent power and other various Legacy based out of the box projects so does know his S***.
His cliff notes on the last page sum up why he decided against going any further or developing anything. Would have been nice if he had actually gone through with it for some solid data from someone who knows how to interpret it rather than just ramble on on the internet.
https://legacygt.com/forums/showthread.php/air-water-liquid-intercooler-lgt-102460.html
If you're serious on doing it then go ahead and collect all the data you can so the rest of us can be better informed in the future.
Share this post
Link to post
The other issue is running a front mount is becoming increasingly hard as you have bigger and bigger crash bars which can’t be cut.
Australia has almost no rules and virtually no wof or cert unless you car gets ordered there.
Share this post
Link to post
There’s always a way to make one fit legally. Just have to think outside the box with fitment. Ever considered a 5th injector maybe even before the manifold to add some chemical cooling? Dunno how a stock ECU would control it though. @Niran still has his meth setup he isn't using last time I heard.
Aussie is worse than us for compliance with stuff like this... Or is it just certain states? I know some of them struggle to the max with getting things legal and wish it was as clearcut as ours is...
Yea he pays the big bucks to have things looking perfect. The engine bay looks almost stock at a glance.
His tuner/builder has done an epic job making that kind of power in stock location too.
Share this post
Link to post
Yeaaaaahp free plug if you want it, is available
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
