Sign in to follow this
ginganinja
Cam pulley bolts
Hi there,
Does anyone have any tips on removing cam pulley bolts that have been loctited?
  • Sad 2
Share this post
Link to post
Hmmmm. Are you doing them with the belt on the cambelt system?
If so, get someone in the car, and stick the car in top gear with their foot on the brake (or jam a pry bar on the flex plate for an auto), and then have a go.
If they've used red loctite, well, you're probably screwed. I'd use blue mid-strength if anything myself.
Share this post
Link to post
Engine is on an engine stand, and belt has been removed.
Share this post
Link to post
I put an cut old belt around them and the crank, clamped/vice gripped the belt together around the crank so nothing could turn
Share this post
Link to post
What pl0x said, and in addition hold the belt firmly on the wheel... or it will jump teeth.
Share this post
Link to post
So you clamped the ends of the belt together against the other side of the belt close to the crank pulley so it held tight?
Share this post
Link to post
7cf04108-36fe-49e9-806e-4af9e8c7d9d5-60.
Maybe it was more like this, can't quite remember but made it work with one clamp and a cut belt
Share this post
Link to post
If the cams have a hex on it use an appropriate sized spanner on it to lock it
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
