03 Impreza Engine Code: P1559
Tawp
After driving about 40km my car throws this engine code
P1559
Chrysler, Dodge, Jeep: Cruise Control Power Management Mode
Seat, Audi, VW: Idle Speed Contr.Throttle Pos. Adapation Malfunction
I have manual swapped it and have tried both manual and automatic ecu. It does the same thing.
I have wired the speed sensor driectly to speedometer. The ecu isnt getting a signal and so the engine light comes on. Could that be contributing to the p1559 code?
Any help would be much appreciated.
The video is what it does at a stand still. If moving its like its gonna stall and bunnyhops until I let off throttle
Edited by Tawp
Finding what the code refers to for a Subaru is probably a better start.
P1559 Air Intake System
https://forums.nasioc.com/forums/showthread.php?t=1711747
It is essentially saying the air/fuel mixture is wrong.
Could be many things, faulty MAF, Injectors, fuel pump, fuel reg, torn intake pipe or vac line.
Checking for intake leaks with compressed air or a smoke test is probably the best starting point.
