wrcfan21
GRB Engine Rebuild
6 minutes ago, Omsin said:
"Shouldn't" - correct, "Have" - evidence suggests (debatable - Subaru motor is quite sensitive)
Was a class action lawsuit in America regarding piston rings, slightly different to bearings but the conclusion was more or less "poor / inadequate design"
That was for the EJ257 but even the EJ207 early on in the GR/GV live cycle was prone to spinning a bearing.
Share this post
Link to post
Yes, correct.
Speculation is that its an oil issue, too thin, sloshing to one side (ineffective baffle), oil pick up failure, low oil. Then again it seems more likely to be from knocking which would then cause a pretty quick sequence of events leading to the self destruction of the motor.
Back on topic, it could be that the OPs motor had developed knock prior to the log above, the damage would have already been done to the crank / rods - which once the engine increases RPM as per the data logging run (even without knock at this specific point in time) would lead the engine to be operating off balance at high RPM and chew through the bearings?
Edited by Omsin
Spelling edit
Share this post
Link to post
Pretty much this, for both engines imo
Share this post
Link to post
Here's some pictures of the engine
https://drive.google.com/file/d/1WX_tSGqM6GVtLin1mQ-bBPFWHA_APeGj/view?usp=sharing
https://drive.google.com/file/d/11gP-tK_yd-DC5WP1Tfv7M9Hlw6v3SMwv/view?usp=sharing
https://drive.google.com/file/d/1jCZcOIaVEEKSzoYUSMgGZ5fQPH2z6KII/view?usp=sharing
The debris inside the bore was not there when the head was removed! It just from a dirty shop rag
Edited by wrcfan21
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
