Sign in to follow this
Followers 0
kamineko
Check Engine Light CEL Codes
113 posts in this topic
check out this page... http://homepages.ihug.co.nz/~ccgrant/celcheck.htm
[table]
[tr][td]CEL [/td][td]Item [/td][td]Diagnosis [/td][td]Fail-safe operation[/td][/tr]
[tr][td]11[/td][td]Crankshaft position sensor[/td][td]Irregular signal received[/td][td]-[/td][/tr]
[tr][td]12[/td][td]Starter switch[/td][td]Abnormal signal emitted from switch[/td][td]Turns starter sw signal to off[/td][/tr]
[tr][td]13[/td][td]Camshaft position sensor[/td][td]Irregular signal received[/td][td]-[/td][/tr]
[tr][td]21[/td][td]Engine coolant temp sensor[/td][td]Abnormal signal emitted[/td][td]ECU adopts a set temp. Radiator fans ON[/td][/tr]
[tr][td]22[/td][td]Knock Sensor[/td][td]Abnormal voltage emitted[/td][td]Sets regular fuel map, retards ignition by 5degrees[/td][/tr]
[tr][td]23[/td][td]Mass air flow sensor (AFM)[/td][td]Abnormal voltage emitted[/td][td]Fuel map set by revs and throttle[/td][/tr]
[tr][td]24[/td][td]Idle air control solenoid[/td][td]Valve inoperative[/td][td]adjusts idle via fuel set by revs, vehicle speed & throttle[/td][/tr]
[tr][td]31[/td][td]Idle switch (EJ20G)[/td][td]Abnormal voltage emitted[/td][td]ECU adopts a set throttle position value[/td][/tr]
[tr][td]32[/td][td]Oxygen sensor[/td][td]Inoperative[/td][td]-[/td][/tr]
[tr][td]33[/td][td]Vehicle speed sensor 2[/td][td]Abnormal voltage entered[/td][td]ECU adopts a set value[/td][/tr]
[tr][td]38[/td][td]Torque control signal (AT)[/td][td]Abnormal signal from TCM[/td][td]-[/td][/tr]
[tr][td]42[/td][td]Idle switch[/td][td]Abnormal signal from TPS Idle switch[/td][td]?[/td][/tr]
[tr][td]44[/td][td]Wastegate control solenoid[/td][td]Solenoid inoperative[/td][td]Fuelcut when WOT at heavy load[/td][/tr]
[tr][td]45[/td][td]Pressure sensor /
Pressure exchange solenoid[/td][td]Abnormal signal from pressure sensor or
pressure exchange solenoid inoperative[/td][td]Fuelcut when WOT at heavy load[/td][/tr]
[tr][td]51[/td][td]Neutral switch (MT)[/td][td]Abnormal signal from switch[/td][td]-[/td][/tr]
[tr][td]51[/td][td]Park/Neutral position switch (AT)[/td][td]Abnormal signal from inhibitor switch[/td][td]-[/td]
[/tr]
[tr][td]53[/td][td]Immobiliser (if equip)[/td][td]Faulty Immobiliser system[/td][td]-[/td][/tr]
[tr][td]61[/td][td]Inhalation valve solenoid[/td][td][/td][td][/td][/tr]
[tr][td]62[/td][td]Exhaust valve solenoid (vacuum)[/td][td][/td][td][/td][/tr]
[tr][td]63[/td][td]Boost pressure relief valve solenoid[/td][td][/td][td][/td][/tr]
[tr][td]64[/td][td]Secondary waste gate solenoid[/td][td][/td][td][/td][/tr]
[tr][td]65[/td][td]Differential pressure sensor[/td][td][/td][td][/td][/tr]
[tr][td]66[/td][td]Sequential twin turbo system[/td][td]Somethings broke au![/td][td]runs like crap[/td][/tr]
[tr][td]67[/td][td]Exhaust valve solenoid (+ve pressure)[/td][td][/td][td][/td][/tr]
[tr][td]68[/td][td]Exhaust valve duty solenoid[/td][td][/td][td][/td][/tr]
[/table]
some other downloadable stuff, cheers log1call
 log1call said:
With reference to poster one's helpful information... There are two pdf documents here...
http://cid-4ca3c3459aaa7f7f.skydrive.live.com/browse.aspx/.Public
about the trouble codes, what the criteria are for them to be set and to be cleared by the ecu to be specific. Good reading if you want to be sure to make a correct diagnosis. Perhaps they could be added to the data file.
Edited by kamineko
Share this post
Link to post
how to reset a v7 wrx computer so all the codes get cleared off?
i have tried to leave the power off for over 24 hours and no luck and also tried to put the 2 green plugs and ign on and off and no luck
basically, i had code come up for a faulty sensor which i replaced but cannot get the check engine light to go off and hence its in limp mode
Share this post
Link to post
 kamineko said:
it may not be the sensor then, it may be the wiring or a connection
i thought about that but apperently you are supposed to clear the codes on the ECU
using either the scanner tool from the subaru people of some form of predetermined activity
like plug something and drive in 1st gear for x km at xx speed.. not sure what the process for the GD seried impreza is
Share this post
Link to post
 kamineko said:
yep however your not going to clear your codes when a problem persists
tru tru.. ok assuming the correct sensor was replaced with the proper unit as per subaru spec..any ideas how to clear the codes..
PS. u got my mail for the track day?
Share this post
Link to post
to my knowledge, and someone please correct me if im wrong....
the CEL shouldn't be on when normal driving, unless there is actually a problem, if u fix the problem the light should go out... but the code will stay in the ECU memory until cleared... so if u light is still on then I agree with kamineko, you still have an issue...
what sensor was it? what code?
[fixed speeling]
Share this post
Link to post
 pappu']
in a GC8 you connect the black and green pairs of plugs, start the car, and drive constantly untill u get an even CEL flash.
if you get another code spat back at you, the ECU still isn't happy with that sensor or whatever.
if its even flashing, its all clear, u turn off the engine and unplug. all done.
Share this post
Link to post
 kamineko']
in a GC8 you connect the black and green plugs, start the car, and drive constantly untill u get an even CEL flash.
the CEL is still on darn it.. was a EGT sensor - replaced - well bolted to earth as needed
got a new dump pipe so there was no place for the egt probe so i just grounded another probe beside the pipe.
the cel is on still after that..
i will plug the 2 green plugs and drive constantly hoping it should clear - will try tonight
car is a gda version 7
Share this post
Link to post
if when u start your car and the CEL is on constantly, no amount of driving with the connecters pluged in will clear it, you need to work out a way of making the ecu think everything is ok with that sensor...
Share this post
Link to post
It's possible that the sensor isn't within it's expected range and so the light comes on. It needs to be connected thermaly so it gets near the right temp. You could try wrapping it in asbestos wrap(just kidding). Better though to get a fitting welded on to the exhaust and plug it back in.
As the guys have said, you have to fix the problem, then the light will go out.
To wipe the stored codes you have to connect all four wires, not just the green ones.
Share this post
Link to post
Share this post
Link to post
what 4 wires?
do you know the colors?
i saw 2 greens as described - what other ones im to look out for
and importantly - what order and colors to be plugged?
do i just plug and ignition on or start and drive the car..
sorry for the hassle but kinda in the dark on this info
thanks'
Share this post
Link to post
if its like my leggy there should be a set of green and a set of black plugs that ALL need to be connected to erase error codes from your ecu, thats how i cleared mine...
Share this post
Link to post
Oh and plug them all in green male to green female and same with the black's to each othyer then turn on ignition, start the car and take it for a drive (prefereably in a 100km zone) until it flashes in a constant pattern, then stop, turn off unplug and your away laughing, hope this helps
Share this post
Link to post
With the green and black connectors together you only need to hit 11kmph to wipe the error codes, so do-able in a driveway and even in reverse
Share this post
Link to post
so just to confirm..
plug in the green and black connectors
and drive more than 11kmph
then turn off engine and take the plugs off..
right?
Share this post
Link to post
Yep.. If the CE light was not on when you were stationary, it should start flashing when you hit 11kmph to tell you that it's all wiped. Stop, engine off, unplug, then you're back in business
Share this post
Link to post
 kamineko said:
[table]
[tr][td]66[/td][td]Sequential twin turbo system[/td][td]Somethings broke au![/td][td]runs like poos[/td][/tr]
[/table]
LOL! Love it. ;D
Apparently there's allot more to 66 if you have a look with a scanner.
Share this post
Link to post
From personal experience:
If your secondary turbo stops working in your TT, and you get Code 65, and you have a ZS Sequential controller, you are getting a short somewhere (bullet connections FTL). A quick work around until you can find the offendig wires and slap them upside the head is to pop the face off of the controller (squeeze each end) where you will find a little button. Press it. This resets the controller. Turn car back on, cel code is gone and secondary is back online.
Share this post
Link to post
So i checked mine today and got 2 error codes
12 and 24
Recently ive had hi rev ideling issues but since ive reset it this morning she looks to be going ok
just to make sure, how serious are these two.. Do i need to be worried and prepair for spending?
*** so now new issue.... its that month! they all coming out the woodwork****
2000rpm idle when i start my car :S wtf is going on with this thing :(
Been perfectly fine for over a year and BAM it all feks out
Share this post
Link to post
not sure about your 12, i wouldnt worry about it, but 24 is your idle control. its probably gunked up, common problem. grab a can of upper engine cleaner and blast it with engine off then running. post up asking how to clean your idle control valve, someone may make a how to.
Share this post
Link to post
cannot see any blak connectors in the sar..
just the green..
unless someone chopped up the blak ones...grrr...
anyway will try the green ones and drive and see if can wipe the darn codes..
Share this post
Link to post
I went into repco greenlane asking for upper engine cleaner adn i was provided a wynns product i add to my oil. (which did make a dif, my VOD seems to be closer to 5000rpm now and not 4000 anymore.)
Im thinking i need one that goes into my fuel?
Gonna go back today i think.
Share this post
Link to post
Followers 0
    • Steve
      Hi all. So I've just seen on Facebook about a thing called The Gumboot rally it's on the weekend of the 7th of April. Goes from Hamilton somewhere down to New Plymouth then across to Taupo and also includes The Forgotten Highway which is an awesome road to drive, as I have done it a few times now. If you are interested go have a look on Facebook should be a fun weekend I reckon.
      Stay safe on the roads over this time there are some CRAZY people out there who only think about themselves!!
    • Steve
      Anyone going to Automania Auto festival tomorrow up at North Shore events centre?
    • Steve
      Does anyone else on here know or own one of the crouching tigers?
    • Matty t  »  gotasuby
      Help me please Hi iv fitted a dump valve to my vectra c 19 cdti 150 bhp. The 1 I bought was a twinport or receculation valve I don't no just bought and had a go of fitting it my self.  On looking at the car I thought I needed to block the 2nd port so have done bought a t and fitted it on the main intake Of The top Of The intercooler to the inlet on to Of The head.  Ran the bleed pipe and td it in to the on top Of The intake now it's just realeasing through the revs rather than when I lift of it's not because I blocked the other port is it thanks
    • WKDWRX
      https://www.instagram.com/p/BPPX4eLDujb/
