readosnr
EJ20 engines are all the same YEAH RIGHT
i though i would post up this technical thread for those who think all ej20 turbo engines are the same (as some people do) just to prove they are vastly different
LIST OF EJ series engines in imports to date (nov 2009)
UNDER 2000CC CAPACITY
EJ15e, Ej151 EJ154
EJ16e
EJ18E, EJ181
2000cc Non Turbo
ej20e, ej20j ej20c ej20d
ej201 ej202 ej203 ej204
Over 2000cc Non Turbo
ej22e
ej25d
ej253
ej254
ej251 (export or aussie spec)
2000cc Turbo
ej20g- single turbo -legacy, impreza, 97 forester
ej20k- single turbo -impreza
ej20h- twin turbo -legacy BD/BG GT & RS models
ej20r- twin turbo -legacy 206kw BG GTB and BD RSB manual trans models
ej206- Twin turbo -BE/BH Auto trans
ej208- Twin Turbo -BE/BH Manual Trans
ej205- Single Turbo -Forester and Impreza
ej207- Single Turbo -Impreza only
ej20x- Single Turbo -Legacy and 08 wrx
ej20y- single Turbo -legacy
over 2000cc Turbo
ej22e- sohc non turbo
ej22g- 22b engine!
ej255- single turbo - forester and legacy (and Impreza Aus spec)
ej257- single turbo -Impreza STI
as you can see there are 33 types of EJ series engines fitted to JDM Subaru Legacy, Impreza and Forester models, and each of them are different in many ways.
for example
-going into a parts department and saying you have an EJ20G engine and you want whatever parts for it will probably anger the parts guys.the EJ20G engines found in the early legacys differ to the EJ20G engines in the up to V2 wrx and were different again to the base spec "V3/V4" wrx/
-the ej207 engine in the ver5/6 is different between sti and wrx models.V7 to current STI also had the ej207 engine and that changed every year in design.
PHASE 1 and PHASE 2 engines
engines built before the MY99 models were released were the phase 1 engine. These had a letter after the numbers in the engine type IE EJ20g, EJ25d, EJ15e
Engines built for the MY99 models and later were of the Phase 2 design, and were named with numbers instead of the letters IE EJ205, EJ255, EJ151
the change of engine meant a change of cylinder head gasket (thinner head gaskets), inlet manifold (inlet manifold bolts were not inline), bell housing bolts (phase 1=4 bolts, phase 2=8 bolts) cambelt, rocker covers (DOHC went from 6 bolts per side to 8, SOHC went from 3 per side to 5 or more), and some other parts depending on spec
please sticky this in the appropriate area. cheers
Share this post
Link to post
so a version 5/6 sti engine shortblock falls where ( i know they are phase 2)
I think we should be careful to distingusih between engine and shortblock reado..?
Top write up btw..
ninga edit: Phase 1 to phase 2 also meant a change from center thrust to Rear Thrust correct?
I found this to qualify
EJ207
to identify an 9/99-9/2000 EJ207
* Wasted spark coil pack off center of manifold
* Inlet under manifold
* Red manifold
Share this post
Link to post
a EJ20 STI engine from ver 5 onwards is a EJ207
(also non sti's in ver 5 and 6 had these as well)
centre thrust were built up to mar 98 with the ver 4. then swapped over to the rear thrust
HOWEVER
ver 4 was built until july 98 and ver 5 was first built from april 98 so ver 5 onwards
SO
v4= either centre thrust OR rear thrust
v5 onwards =rear thrust
Share this post
Link to post
You'll also find a fair bit of variation in the actual engines themselves. There is a Big difference in between the early EJ20Gs and the later ones in all sorts of areas
Share this post
Link to post
i have had a v7 wrx with ej205 (the build plate read ee205 for some reason - spelling error perhaps)
that would still be rear thrust right?
Share this post
Link to post
Guest SPANKU
the Ej205 are usually the short block that aint semiforged. usually comes with a TD04
my old v5 RA also has a EJ207 on it, where my mates wagon where it came with a TD04 has a EJ205
this is new to me i didnt know that the V4 are dual thrust, as i just rebuild a motor for my mate ussing a ver1 wrx crank in a ver4 short block
Share this post
Link to post
i changed the wording for Ver 4 so it didnt sound like it have both types of thrust types on the engines
now says EITHER instead of AND, sorry to confuse anyone
the ra and some sedan wrx engines had the ej20k(or later the EJ207) name even though they were not sti's.
this doesnt mean they had forged pistons, just a different complete engine package to the wrx wagon/base model wrx
Share this post
Link to post
Guest SPANKU
yeah or you can also look on the side of the covers of the heads,
Ph1 has 6 bolts
Ph2 has 8 bolts
Share this post
Link to post
a singapore spec sti is when someone in nz thinks they can fool people into buying their wrx coz it looks like an sti HAHAHA
there are a few cars in nz that are singapore spec. i owned a shell of one for a couple months that couldnt be vinned. it was a V5 wrx sedan from singapore, that had a few different things- it was like a de specced wrx.
singapore spec cars have a 17 digit chassis number like the aussie spec cars (jf1gc8kl54g002718 for example). so if that "singapore spec" car had a JDM chassis tag like GD?-002475 then it def wasnt a singapore spec car.
Share this post
Link to post
so when it comes to a 2002 V7 wrx and a 2003 V8 wrx what are the mechanical differnces? if any? I
thought the only real diffenrce on them was the headlights due to the "bugeye" being considered ugly?
me and my mate have just brought a V7 and V8 so just comparing :P
Many thanks Guys,Ta Dan
Share this post
Link to post
heres a good one
how do u tell a STI engine apart from a WRX engine not including the red mani and injectors etc...how can u tell the blocks apart without removing heads??
Share this post
Link to post
 WRXONP said:
something actually factual?
is it only v1-2 where the non sti has the ribbed rocker covers and the sti has smooth?
A helping tip, the year of engine manufacture is stamped underneath your oil filler cap (yellow one) obviously it dosent say Sti but u can tell if the engine is the same year as the car giving an indication that it is original. Well yr ganna be suspect if the engine year dosent match the car ay
Share this post
Link to post
Nice info! :)
but i didnt know that the 22b engine was "called" ej22g, reading on internet and searching quite a lot I found that the 22b engine ( apart from the fact that is a 2.2 liter engine and its a closed deck block) uses the heads of the ej20k which are known to be one of the most aggressive cams and it also uses the turbo from the v3 sti the vf23.
so by saying ej22g we are saying that its a 2.2 liter engine with cams of ej20g?, <--- I disagree with the statement cos Im pretty sure it uses the heads from the ej20k which revs up to 8300 rpms. ;D
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
