suspect electrics?
paradigm
Looking for an opinion on what to do to help problem solve my misbehaving wrx!
(its a my97 wrx wagon auto)
It has never missed a beat apart from say over the last month, were occasionally it would (at low throttle opening) i.e coasting at 50-60kmh, just stop running (in gear-revs drop), and then within a second or two resume its happy driving. This would happen every hour to half hour of driving time.
Now it has become once warm will do its thing and stall completely, then sometimes takes a couple of goes to restart, then continues pattern drives-stops-stalls, while motor is warm. It isn't a splutter like running out of fuel and it isnt losing power to the dash etc, so my hypothesis from searching is that it could be the coilpacks? Or another aspect of the ignition-like it is halting the spark?
Also No cels are showing atm, and it has had an airflow meter issue in the past (cleaned it & it came right)
Any ideas what the next step is? ie get coils checked by an auto sparky? Or something else? Any help appreciated :)
if it had AFM issues and all you did was clean it, I would start there, try to borrow a matching one that you know is working fine.
FYI air flow meters can be reconditiond cheaper than buying a new one if you've got the pre v5 type (v5 onwards are alot cheaper to buy brand new)
