 boon said:
Performed TCU reset so I can do a relearn.
Also finally pulled the ABS fault code, looks like it may be the Brake Pedal Position sensor?? Is that a thing?
Have a look through a cruise control installation thread, if I remember correctly someone had a ABS light thrown at them when they replace a break pedal switch and didn't adjust it correctly (too short).
soba's explained it well. Sometimes the switch can fault and have incorrect resistance readings resulting in an ABS code. Might be worth trying a second hand replacement or even a new one?
 Marky said:
Got half my weekend plans taken care of, haven't taken a manifold off a subydoo before but can't be that hard surely. Is it possible to just unbolt it enough to lift an inch or so higher without having to disconnect errrrthang?
Will need it off completely unless you hack the original intake into pieces. Then IIRC I had remove the drivers side fuel rail to get the original out. Then bend the fuel lines bolted under the mani slightly to get the new intake pipe in neatly without being squished. It also needed some length trimming to fit perfectly:
http://clubsub.org.nz/forum/showthread.php?39690-BE-BH-replacement-inlet-hose-for-TT/page2
**** that makes my life easier
 Marky said:
Got the under manifold silicone intake in, that's half a weekend I'll never get back.
On the plus side, holy turbo sucky noises batman! I dunno if it's any faster or not, and I don't really care either
will make a difference if you get a tune. may **** around with a/f s if not, maybe check them with a wideband for piece of mind if your not going to tune...
did my last service on the wrx before the cambelt change, also only 800 of the loan to go now. checked the cv's as to my knocking noise: no play of cv's, pretty sure it might be poked struts. or on their way.
now: do I go coilovers and cert... or new struts, dont really wanna get coilovers before ive got the 17x8's I want though, as im not overly keen on the re-cert cost lol
It would be a very, very pedantic policeman that pulled you up for 17x8's uncerted.
My cert plate says OE wheels and I've had 17x8 aftermarket wheels for a long time, never been an issue.
Ive been pink stickered once for having 16s whilst cert plate stated 17x7...some cops are just out there to get you even though they are still correct.
