Booked a tune at STM... I ****en hope i can get my clutch working properly by then or I am going to look like a right tyre kicker.
booked and cancelled two or three times already due to overly optimistic view that the motor was fixed.
No further ahead on oil usage just fingers crossed?
Correct, assumption is tune is causing problems. I think it's a 60/40 chance against that being the case.
Decided leaning out the tune myself was too much trouble and too dodgy... plus my clutch decided to start
sticking to the flaw as soon as I got the wideband in. Tried bleeding it 4 times now, and still isn't quite
right.
Replaced the clutch slave, filled and bled new fluid. Took us forever to bleed the damn thing, ended up doing it with an F-Clamp holding the pin in on the slave
and holding it upside down so the air would actually come out.
Anyone else got an easier way?? The only other solution seemed like a vacuum bleeder but don't own one of those.
Been having the same problem... bleed it 3 times and it made no difference. 4th time I did what you did and used a g-clamp and
help it upside down... still didn't help. It came miraculously right when I pushed right back on the clutch fork a few times
once re-installed... so basically pumped the system backwards. It might just be a temporary fix though.
Mmmm... mine seems ok but who knows... it was a good 20min drive home from my mate's house after we did it and seemed good so might just act ignorant for a bit and assume its fine.
No reason to think yours isn't fine... mine just started playing up out of the blue though... so I might still have something not right,
or it could just have been really old fluid.
Upon pulling the rear shock out I realised i'm a bit of a knob and that the regreasing only works on the front inverted struts. Decided i'd put a small amount of grease between the upper rubber spring mount and the metal part of the top hat, put it back together and wholla, no more irritating squeak. Dunno if it was the grease or that it seated slightly better this time when installing it but happy either way.
