53 minutes ago, Andy_Mac said:
Used a claybar for the first time ever, what a goddamm difference. Not sure why i've never bothered before
Amazing how much crap it picks up off a seemingly clean car :) Have you performed a plastic bag check afterwards?
Found her a proper set of GRB Brembos :)
5 hours ago, loner said:
What the labour component and how many hours?
The club should start a database of all professionally performed work done around the county to get an idea of where
the mechanics are slow and fast.
Breakdown:
Labour - 5h @ $89 = $445  (replace steering rack bushes, strip engine bay, lift engine, replace gaskets, reassemble & clean, align headlights)
Steering Rack Bushes - $68
Rocker Cover kit - $135.48
Total (incl. GST, shipping and materials) = $761
Na. Whats the plastic bag check?
What was wrong with the old ones. Didn't you manage to get them fitting in the end?
Put your hand inside a plastic bag and have a feel of the paintwork - usually do before and after, reveals lots of surface crap which you don't really feel with a bare hand.
Brembo comment should've gone as a separate message, clever forum combines consecutive posts :/. Anyway, the rears do fit, with the brackets but are offset too much and pads do not cover the disc completely. GRB Brembos are straight bolt-on, no brackets, no drum inserts too as the handbrake is the same diameter as STI
17 minutes ago, willisnz said:
What did you get?
This is the usual set up I go for because its cheap and it does exactly what I want (except for the amp - I usually go for an earthquake amp but it was out of stock everywhere)
1x Pioneer GM-D9601 Mono Amp - 24000w max @ 1ohm - 1200wrms @ 1ohm (I'll be running my setup on 1ohm)
2x cheap 12" Pioneer TS-W311D4 subs (4ohm Dual voice coil) (1400w max - 400wrms each)
1x cheap set of pioneer components for the front doors TS-G1605C
1x 4gauge kicker amp wiring kit (their wiring kits are so nice - some of the best wiring I've used)
I have an existing pair of jvc coax 6.5's for the rear doors that I have had sitting around for a while
This will all be running off the factory headunit initially (kenwood unit)
Whats that cost approx if you dont mind me asking? I know how to install stuff but dont really know (or care tbh) whats really good. I just want a nice sound.
1x Pioneer GM-D9601 Mono Amp - $350
2x cheap 12" Pioneer TS-W311D4 subs WITH box - $250
1x set pioneer components TS-G1605C - $76
1x 4gauge kicker amp wiring kit - $129
The subs and amp are a pretty good match number wise so shouldn't have any issues finding the rattles in my car
Wow that is cheaper than my sub and amp
14 hours ago, ADIKT said:
What do you have? You are more than welcome to see how it sounds in a couple weeks when I've had time  to chuck it all in
Would be good to hear it
I have
ROCKFORD FOSGATE R500X1D PRIME SERIES AMP MONOBLOCK 500W RMS
HYPER DRIVE SB15 SEALED 15" SUB BOX
HYPER DRIVE AK8 AMP WIRING KIT 1000W
ROCKFORD FOSGATE P1S4-15 PUNCH SERIES 15" SVC 4 OHM 250RMS
Did a compression check on the engine I'm going to put in my lepracy. got the All clear so now I've gotta strip some more parts from it, clean the block (motor came from a burnt out shell) and then start reassembling all the bolt on parts. Can't wait to finally put it in the hole
