55 minutes ago, McMatty said:
They were saying that because i have 4 pot fronts that the only ones they could sell me that will work are the DBA ones that theyd also have to order, a mate of mine who works with a different repco store said that DBA rotors are restricted to being sold only to AA service shops so theres something dodgey there, BNT said the pair will be $320ish with trade discount, also turns out if you use a WRX license plate when the car is being searched the rotors are generally cheaperCLBSUB is available
I can sort it for you a ton cheaper than that if required.
My mudflaps are not ornaments!
Look at the lovely clean paint behind them, some people may hate but the rally armour flaps really do work well even if they are a tad overpriced.
I spent like 20 minutes hosing mud off of my wheel wells, subframes, sills and control arms. Maybe they should make some mudflaps for those areas too :P
  • Like 5
One of the first things I did when I bought my STi was put on a set of RA mudflaps. Agree they are not the cheapest out there but you certainly get good quality.
6 hours ago, SWAGGN said:
Would be keen for new rotors at that price if they come up
That is trade cost for the cheap and nasty brake rotors. Stoptech if I remember correctly. You will have to pay GST and likely freight on top of that.
If you know someone with who gets trade price at BNT then it is a good deal.
Edit: definitely wasn't stoptech, was that 'Trans... something' blue and red boxes.
Hmmm, well, great day for me. Last night cars temperature nearly hit red line. Fortunately for me have today off work.Checked header tank and sure enough it was empty o.O Chucked water in, checked hoses and surprise of surprises there was no leak!!!! Then I noticed water dripping from heat shield on left hand side and thought 'this is strange' so jacked car up and lo and behold there was dripping which explains where all my water went! So I'm figuring it's my water pump. Contacted SAS who said it should have been done when cam belt was done (obviously) but the workshop I bought the car from said they did the cam belt when I bought the car some 40,000k ago. So Richard and I have worked out that they probably did do the cam belt and didn't bother doing said water pump. Probably why the garage has since shut down. FML. Anyways, have chucked bars leaks in as has water pump seal conditioner so hopefully it'll hold until I can afford to get new water pump. And this is my picture
Edited by B4 I was 250T
spelling error
Jeeeeez I wouldn't put any of that additive stuff in a car I didn't plan on immediately selling.
All some of those additives do is swell rubber seals, including ones that really shouldn't be swelling.
Bugger!
Sux about the water leak, water leaks drive me craaaazay. be sure to tell sas or whoever does the work tht that stuff is in there, and to flush the cooling system good n propa. That additive could load up your radiator full of gunk
5 hours ago, pedro said:
Td05 20g
You getting it tuned? Keen as to hear your results when you done as I'll be using a similar turbo on the rs
Yes .Keith stewart will be tuning ..
Have got to fit stock headers and modify turbo mount to sit turbo level..
Then modify down pipe to suit..
Then tune for 300whp..
Run it for a while like that and then rebuild engine and run in..
Followed by touchup tune with maybe another 20-30 whp..
Sounds easy...........................
But its not.
But its not.
Nice
my 20g goes in stock location, stoked I don't need to get anything fabbed as my budget is being streeeeeeetched
