21,921 posts in this topic
Wrapped the stereo trims from the legacy. Thought I'd better throw it a bone recently, it's been neglected for a couple weeks. Ty Auckland fuel prices! Also, got a new daily... be70b5ce77c75344e510d6ab86e73e53.jpge16e7c8b8b9081fdde02ddf5d1dfdab4.jpg1fdef6b715a250a93093de523e21ca00.jpg
Sent from my SM-G930F using Tapatalk
2 people like this
Share this post
Link to post
Good job on those.
Wish it wasn’t a matter of semi destroying the door cards to get them seperated to wrap the silver piece in them. Not doing the whole lot would bug me.
1 person likes this
Share this post
Link to post
12 hours ago, ADIKT said:
ffuuuuuuuu
know them feels
1 like = 1 prayer xD
3 people like this
Share this post
Link to post
Good job on those.
Oh really?! That was my next project haha bugger. May have to wrap them on the door itself then. I'll post here if I'm successful....
1 person likes this
Share this post
Link to post
People have done it. The segments just have those melted plastic sorta rivets so just need to have a plan for re-securing it later
Share this post
Link to post
Hot glue to re fix them in place potentially? I'll try it at some point, maybe from a wrecker instead. Anyway, reinstalled the trim peices and it looks slick! Super stoked.
1 person likes this
Share this post
Link to post
Can’t see hot glue doing the trick long term. Some kind of plastic glue, epoxy two part resin or PVC cement, would want to check the plastic type before using that though.
Not so easily removable if you change your mind though I guess
1 person likes this
Share this post
Link to post
Fitted a Hardrace mount set. Massive improvement,
2 people like this
Share this post
Link to post
Similarly I fitted some KEIN mounts recently along with some solid spacers to replace crossmember bushes.
Greatly improved shifting... it turns out some muppet used a standard impreza or legacy mount
for the transmission... soft enough to bend with one hand. Anyway, the car is hellish loud now,
but nothing some earplugs won't fix... the vibration is nothing to worry about.
2 people like this
Share this post
Link to post
So you wouldn’t recommend anyone use those mounts for a car that requires some civility to remain?
Share this post
Link to post
The major noise I suspect is due to using solid bushes in the crossmember... the crossmember bushes are actually quite soft
usually and so even with a hard transmission mount, there would be quite a bit of dampening.
Edited by Loren
1 person likes this
Share this post
Link to post
New pitch stop mount is in. Has made a hell of alot of difference, with zero harshness thanks to it having hardened rubber bushes rather than the usual poly.
No more repeated rocking when coming on/off throttle at low revs is a massive bonus. Turns out the original was in pretty bad shape, the small side bush was flopping around all over the place.
3 people like this
Share this post
Link to post
Replaced serpentine belt, idler pulley and tensioner. Took me maybe half an hour working in the dark.
With that said it took me another half an hour to remove and reinstall the damned battery...
1 person likes this
Share this post
Link to post
Finally managed to get my 5 metre land yacht out of Auckland and sailed down to Karangahake gorge yesterday. Such an awesome cruiser and averaged only 5.5L/100km, hapi daze! 9_9
3 people like this
Share this post
Link to post
Today I cleaned up the headlights on the wagon and sealed them so hopefully it actually lasts a while before going yellow again. It was really hard to photograph with the cloud and reflections.
abUDhB1.jpg?1
4 people like this
Share this post
Link to post
That looks great! What brand and where did you source it from?
Share this post
Link to post
Hardrace from Redline. The only one I could find that didn’t use poly bushes
2 people like this
Share this post
Link to post
I said fk it and bought a running WRX motor off my friend with new cambelt, tensioners and waterpump for $500.
I'm going to slap it into the RA, shove as much e85 down its throat as I can and give it full send. I'm tired of not having a running RA.
Sent from my TA-1012 using Tapatalk
9 people like this
Share this post
Link to post
Finally got around to installing my new rear sway bar links all ready for a cert tomorrow. Went over and under my car to just do a self check and it looks all okay. hopefully she passes!
Excuse the mud...Had fun im my mates paddock
1 person likes this
Share this post
Link to post
Tried for the third time to get the before/after Dyno sheet for a dyno tune I had done two weeks ago. Tuner is no longer even replying.
Share this post
Link to post
Do you have the after dyno sheet at least? Who is the tuner?
Edited by Loren
Share this post
Link to post
