On 7/07/2019 at 12:00 AM, Individualities said:
Cheers for that. Quick Google myself earlier today yielded that. The articles I found said to use a SPDT Relay - is that the same as a Change-over?
You use 87A - that's what the articles I found said to do.
Definitely tackling this next week - cos then my car is done, till I put the 19"s on it, once my 17"s have worn out!
Exactly as @IZichard said.
Works a treat and the relays are cheap from Jaycar (SY4070):
SY4070-30a-horn-relay-spdtImageMain-300.
Share this post
Link to post
Installed mudflaps / stone guards on the front of the WRX (who cares about stones being flung up behind me 😛 ), also retrofitted LED's in the interior fittings.
Edited by Omsin
Share this post
Link to post
Mca "street performance" Coilovers installed, with custom spring rates and their "stealth" option colouring.
brembos on, had to drill and helicoil one of the front caliper bolts as it was stripped.
Bendix heat treated vented slotted front rotors with z series pads, Bendix slotted vented rears, again with z series pads. Also stuck in some endless handbrake shoes, should make a nice difference.
Bled it all out, both sides of the calipers, pedal is still a bit squidgy in the first little bit of travel. Need to re bleed it, but gotta get more fluid first.
Looking forward to getting this beast tuned. Been driving it around for a while on wastegate pressure and break in tune, and it absolutely hauls arse.
Share this post
Link to post
Set my whiteline sway bars to full stiffness front and back, think it’s the equivalent of 22.5 front and 23mm rear - Handles amazing! Linear oversteer when you start to push it harder through corners (the opposite to how Subaru set these up from factory). Also changed the dark coloured clutch fluid which was actually really easy to do, made almost no difference tho disappointedly
Share this post
Link to post
When I did pass/rotors on mine I had the same issue, apparently there is a certain order you are supposed to do it in.
Share this post
Link to post
Driver front, passenger rear, passenger front, driver rear. Yeah did that.
Left the car to sit overnight, pedal feels a lot better today. Will let it settle for a few days then re bleed.
Share this post
Link to post
I usually find it best to keep your foot on the pedal when you tighten the bleeder screw (keeps positive pressure in the system?). Start car, pump brakes a few times until the pedal goes hard. Job done :)
Keep in mind with new pads and rotors that your brake pistons have been pushed back in a lot further than when your pads and rotors are thinner, make sure to break in the pads and rotors for better initial bite and prevent rotor glazing.
Edited by Omsin
Share this post
Link to post
Yep, done it once or twice, going to let it settle for a few days then re-bleed when I'm not rushed for time.
Brakes work fine, just slow take-up and a bit spongy. It's fine, just need to stop rushing. Lol
Share this post
Link to post
You have dixcel pads and rotors yah muppet lol not bendix
Share this post
Link to post
Ye that one.
Got em bedded in today, yeesh they pong when they get hot. But good god it drops anchor confidently.
Mca struts are freaking magic too, it's so planted!!
Definately needs a tune though
Share this post
Link to post
It doesn't look like much, but I've already got a short shifter and the main shifter bushings installed (hence no photos). Anyone else geek out when they order genuine parts that you wouldn't normally see or think about? I went through an exploded diagram of the shifter assembly on my WRX and decided to replace all the parts which connect or play a part in the shifter movement (shifter to transmission case). I even tried to order new nuts and bolts but they weren't in stock haha (little OCD)
Share this post
Link to post
On 17/07/2019 at 11:30 AM, Omsin said:
Anyone else geek out when they order genuine parts that you wouldn't normally see or think about? So  I even tried to order new nuts and bolts but they weren't in stock haha (little OCD)
No, but I have a full genuine gasket rebuild kit if you want photos.
  • Haha 1
Share this post
Link to post
Nobody enjoys replacing gaskets :/
  • Haha 1
Share this post
Link to post
Try having to replace a single crush washer behind the timing belt cover because it’s leaking oil.
Share this post
Link to post
Spent all weekend wiring up a proper fuel pump supply setup along with a DCCDPro FuelPro controller. Seriously hoping it starts right up tomorrow when I do the final touches, really don't wanna be pulling the interior apart again to find where I went wrong.
Share this post
Link to post
I pulled apart the rear floor to try and find a tow bar wiring harness but JDM Legacys dont have them so looks like i will have to splice into the factory wiring(which i hate doing even though i do it work all time)
Scored me a Tow Bar for my BP5 from Subwrecks so going to try and fit it soon
Share this post
Link to post
Trying to fix dents and rust, this job takes more than expected.
Will be continued...
  • Sad 1
Share this post
Link to post
I’m going through the wiring and vacuum placement on my defi boost gauge and everything seems to be done properly, but it doesn’t steadily climb or hold its position, the needle just sort of runs around the general area. Is this from the internal waste gate flapping around or is there an issue with the stepper motor or something? I can take a vid if needed.
I should also note that during the opening ceremonies when the gauges sweep through the full range of motion my boost and egt are quite jerky on their way back down.
Edited by Abomb
Share this post
Link to post
Pretty hard to get those wrong. Have you double checked it is in the correct port on the control unit if it is a model with one?
Where is the vac teed into?
Share this post
Link to post
I agree, I didn’t install the boost gauge myself as it comes with the car. It is tee’d off a manifold reference and then teed a second time.
  • Sad 1
Share this post
Link to post
I should note that the second t was my doing, I used it as vacuum reference for my gfb ebc. I’m debating getting rid of the defi boost gauge all together since having two boost gauges is a little silly. But the problems with the defi unit were there before I installed the ebc.
Share this post
Link to post
2 hours ago, Andy_Mac said:
What model is the defi?
Not sure.
Edited by Abomb
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
