Ok so I got a few problems with my 1998 Wrx STI, I know a little but not alot.
Here goes, Morning start up is fine, then I drive for 5 minutes and it brings up a cel. I park up at work for 8 hours, come back to car and when I start it its like it idles very very low and cuts out sometimes until its warm, it produces this same symptom everyday.
I connect the 2 black diagnostic plugs to see what code it throws, it throws code 24 Idle air control valve ( I have tried multiple IACV\'s )
I clear the code, drive again and it comes back, I notice it is more likely to come back when I am changing down through the gears 3rd to 2nd.
I disconnect the black connectors and connect the green ones and drive the car for a couple of minutes, it throws another cel code 51 Neutral Position Swiitch.
I turn the car off, with ignition on I depress the acceleration pedal then bring it back up half way for 2 seconds, then I start the car and hold the revs at 2000rpm for 1-2 minutes then it throws another cel code 33 Vehicle Speed Sensor, The speedo still works fine.
I was wondering if anyone can shed some light on this situation, as I have already changed the neutral position sensor and I still get the same code reoccurring ?
Could any of the above sensors be causing the others to bring up a cel ?
Would love some input
Cheers ;D
