No.. I think the previous owner removed it..
What just the bulb in the cluster or ???????
PS that quote of saying the previous owner removed the diag check made my day
haha... yeah its abit syupid I guess...
I cant find nothing under the dash board for diag test..
hey guys,
I dunno why my 91 legacy miss fires when driven.
even on idle, car loses power then turns off it self some times(on cold start).
while driving, when I put my foot on the excellerator, car loses power then picks up power and loses and so on..
not much power but turbo still spools up as usual..
could it be knock sensor , 02 sensor, MAF causing this problem?
Yeah ither way the gate is going to close when you take your foot off the gas. (spring pressure) as mentioned above swap the hoses over Gate one and gauge one and shud be fine. The flutter is coming from the pressure chages in that boost hosee (turbo outlet) due to the bov not opening correctly or cant flow enough air. You wont get the flutter through the gauge when you swap the hoes over cus the throttle butterfly will block the pressure changes and ul just get a nice vac reading (wich is correct). And the wastegate doesnt need vacume so it will be happy just coming off that pressure hose where your gauges is in the first pic.
hey thanks! I changed them today.
the gauge hose was abit small to fit on the fat one where wastegate use to be on,, I did put them on but the hose isnt all the way in, its half way in.
it is tight tho
Yeah I was thinking wtf has happend here as dont seem usual as others..
but the hose for wastegate is too big to fit on the turbo. maybe I need to get a smaller vaccuum hose for the wastegate? but I dont know how wastegate is working fine and boost gauge is reading 12psi which is right..
Im not sure what boost controll it is but I guess its standard as old owner didnt state he had changed the boost controller. but I see the hose from the bottom of the boost controller is plumbed onto the intake pipe.
Sorry, Im not expert on boost controller, wastegate, vaccuum etc..
my external wastegate is plumbed here on the thick one
middle one plumbs the blow off valve
and the other one is plumbed on this below:
the thinner one
Hey guys,
I have a boost gauge in my car, had it since when I got this car,
But I noticed that unlike other boost gauge they install with T-fitting,
My car boost gauge hose is from intake vaccuum to boost gauge only(No T-fitting)..
and when I boost, gauge goes up and when I take foot off, I see gauge needle bouncing up and down really fast and can hear flutter noise from the gauge..
Is this normal?
