I have figured out how to set the time on circa 2004 Outback/Legacy.
Set the time:
The Japanese Navi system sets the time via GPS settings to Japanese time. There is a setting in the GPS menu to turn off allowing GPS to set the time. Turn off this setting, then disconnect the battery and you will be able to set the time when you reconnect the battery and turn the car on.
1. Go into the Navi menu
2. Press the button on the far right – Configuration
3. Press the System button, highlighted on the bottom:
4. Scroll through three screens, then toggle the bottom option, Clock Settings, to off. I believe this is the option that turns off GPS from setting the clock:
5. Disconnect and reconnect the car battery so you can get the option to set the time:
6. You will now need to turn off the annoying voice assistant. Go to Media and press the AV settings button, bottom left:
7. Select the second tab at the top of this screen:
8. Select the Audio output settings button in the middle of this screen:
9. Set the Voice Assistant to Off
