Thats a good guideline, on our dyno (PBMS) GRB 6speed with the stock turbo would make anything from 220kw-235kw (295whp-315whp), auto is a different story, they make 200-220kw (268whp-295whp), there is sooooo many factors on what will actually make on the dyno, sticky tires, bigger heavier wheels, all of that will read lower on a roller dyno. The highest GRB that I have seen here with the stock turbo make 240-245kw, but one of the biggest differences, is that it was running 17" lightweight wheels, so the engine may be making the same as any other GRB but because of the wheels, it goes better, and the roller dyno show you that. I wouldn't be thinking about a number, I know that we live and die for the scale, the dyno, the 1/4 time, etc, but just focus on the experience, the fun on modding your car, and the driving pleasure of the results... best bang for buck is going to be, downpipe, turbo inlet, then maybe catback? or catback and CAI in the same place? to be honest at that point probably is going to be better with an aftermarket ECU. If you want to go to the track and keep it safe, probably a good oilsump is the best mod, and then just don't push lap after lap because the oil temperature is going to go through the roof and then... knock knock knock... rod bearing failure. Do not get me wrong, you can go to the track and have fun, but you just have to be conscience of a few things to keep it fun and reliable. As the tuner of PBMS, I would love to tune your car, but if anyone ask me, I will always recommend a local tuner (if there is a good one around), is just like your doctor, you don't want to have to travel 3-4 or whatever how many hours to see it, and less there is a good reason to choice that doctor to start with.
On the sti everything max out at the same time, turbo and fuel system, so if you are not going with a bigger aftermarket turbo, stock injectors and more than enough. Your car with a downpipe and a tune is going to be fun, and a massive difference to the stock car, I am sure you are going to be happy with that, if you go turbo inlet, choice the bigger you can find for your application.
