acidbath
    invercargill
acidbath's Achievements
  1. does anyone know who i can contact in nz to get a rim from?
  2. K&D are probally one of the best in town with performance cars and good value the other is waverley motors both very helpfull and good value, on a side note ive been going to autoplex for years for wofs and are now under new ownership they have really sharpened up, Daniel is doing a great job there but a little pricey and very limited subie experience
  3. i havent been about for a while and need to get ass into gear and come on 1 Binkz needs to go and subbyboy88 just got new legacy so surely a few from southland you can come with me if ya want SkylineObsession the wrx is noisey rattly generally pretty uncomfortable but legal and goes everywhere
  4. I would go to warren kett at fleet imaging tell him rodney sent ya he look after ya, is that craigs old car?
  5. You would be after a car painter then?
  6. bilsteins been rebuild about 6 months ago mite try 1" spring helpers see if it works provas just too soft spring rate for wagon me thinks
  7. yeah i have seen them think i will try a set and see how i go thanks bud
  8. Ok currently i have prova springs with factory bilsteins but the issue im going to have is with the rears, i plan on towing a 16ft boat which has a total trailer weight of 777kg, now ive towed heavier but the back just slumps too low and tow bar hits in certain places, really want to upgrade rears even higher than factory as i tow trailers every week, someone here must know best option for me, any help appreciated
  9. sort of lucky was only a side tank seal and was $70 to be fixed however back to original problem of running like crap lol
  10. no bubbles in overflow i got radiator back today seal had blowen on tank cheap fix will put back together and goes in for tk test on monday fingers crossed thanks for help
  11. ok so i have a v2 wrx now its been running like crap when cold better when hot but still not right kinda runs on 3 intermittently, changed afm new o2 coils and plugs, today it started spewing water out of side tank not a crack but gasket ont tank, with cap off header tank few revs and blows all water out there was a white frothy foam that came out on ground when i noticed leak didnt overheat luckily, any advice would be appreciated.
  12. yeah runs mint when warm, thanks mate i will replace that and o2 sensor just to be sure
  13. whats ect? you mean exhaust crosspipe?
  14. my non sti wrx is being a prick, when its cold overfuels maybe runs like crap farts around etc fine when hot tho. Replaced afm and fuel filter no change. No error codes, i have another ecu with speedlabs chip in it and it give me an error code for o2 sensor and injectors, would an o2 sensor cause my issue? and why wouldnt factory ecu pick it up? any help appreciated
