So after getting the RS running again it bellows piles of white smoke out of the exhaust. I mean piles and piles of white smoke!!! which smells quite bad too.
Now it never used to do this, apart from cold, and maybe a little at idle. So since last running I have been pulling it apart over the last year, internally the engine has stayed stock, I've added a VF23 and a pile of other bolt on mods.
Now that it back together its running, idles nice and smooth I haven't been for a strop as its not registered.
It will badly need a tune, but I want to make sure I have as much sorted before it goes on the dyno, as fixing probs on the dyno costs more than I have.
I did a compression test before pulling the RS apart and got nice even compression across all cylinders. Usually I hear white smoke is a sign of a head gasket fault, but given this wasn't happening before I pulled the engine down, I'd be surprised if the gasket failed while the car sat round for a year.
What other causes could there be for heaps of white smoke? could it be a turbo problem?
Thanks
Q
