Failed a wof and I need to fix it and get it re-woffed for next Sunday's Slipway autocross on 21st.
Anyone experienced this problem before and able to help?
Al
if the front pipe is leaking, just replace it, easy :)
-smurff
-smurff
The VTNZ place said 'front pipe' but turns out it's the front pipe of the exhaust system under car after the gearbox, just before it bolts up to the resonator.
 al']
-smurff
oh, i see. bugga lol
get the welder out?
-smurff
 smurff']
-smurff
get the welder out?
-smurff
Not in an easy place to weld. Can it be wrapped? Or does it need to be welded?
Would only cost you $30 ish to get a new bit of pipe bent and welded in place
okay will take it in to midas tomorrow then
Guest loren
you don't need the STi for slipway al, use the tomato.
You're developing quite a devilish sense of humour Loren. The tomato would toast STIs for a motorkhana at the slipway but not an autocross.
Must... get... maximum... points...
Guest Charlie
im not even running the mirage, i want to get somewhere this time!
legacy is waay more fun at slipway anyway ;D
Guest Oscar
Saw your mug in the paper there the other day.
Guest SPANKU
Al if your downpipe is standard i got one or two you can have for cheap. its easy to fit also
It's quite a long 2 1/2" downpipe. It goes past the gearbox.
Guest Oscar
 al']
USDM spec?
 Oscar']
USDM spec?
Don't know. But it should be good for mixing gases. :)
Update: Took it to Midas and they found 3 holes in the downpipe :'( - at the wastegate, the hole, and a rotten joint at the far end. They fixed them all. Sorry Loren, but the tomato won't be making a show after all ;)
 bubblz said:
how much they fixed it for ya? those guys in newtown midas seem pretty good to deal with...
It was Porirua Midas, and they were also very good - $171.
Guest loren
 al']
USDM spec?
oh well, there goes your excuse for me beating you then :D
Well i AM coming down....but i dont do autocross very well :(
Hopefully I'll have a new job soon and Sunday will become free for auto-crosses etc..
then i can get out there and start having a bit of fun with the rest of your guys :)
