Smart ideas: removing diff bung
funkytown
in case someone has struggled like me before...
top bung is stuck in the rear diff (and is in the car)
A 1/2' drive bar doesnt work and a whole lot of extenders and big bar doesnt work either...
Any smart ways to get it out? Impact gun i did think of...
Suggestions welcome.
the bung square is getting a bit munted as well so if anyone has an old one they want to give me so i can replace my bung (lol) one that would be awesome
  • Replies 55
 dubbedup']
are you trying to fill with oil...
[me=dubbedup]thinks about where it is located[/me]
yup thats it - effectively the middle bung to fill with oil.
[quote name='Koom said:
Apply heat.
Give it a good solid whack with a hammer to break any seal in the thread (a big punch or similar is good for not wrecking the bung).
Try tightening it a fraction then undo it.
smacking alloy is ok?
hmm will have to find myself a heat source
thankyou sir
Yeah its on a tapered thread so they lock up in there. I had the same with my diff drain plug. I had to swap the whole rear cover.
Most impact drivers are 1/2" drive anyway. But if its that tight, I doubt an impact driver will do much.
Did they not notice it while the diff was being reco'd??
But if its all rounded out like mine was, then you're stuffed. Every time I turned the bar it would climb up out of the recess.
I'm guessing the diff is in the car, right Jon? And if so, I very much doubt he wants to take it out yet again!!
yer to all - its in the car on the ground - so no nice way of putting a big long bar on it..
maybe if i pour a little in the bottom bung with the rear as high as i can get it, then tow it down somewhere where i can hoist it up and then swing a big bar from the bottom
yer mines also starting to get a bit rounded :-[
where does one find a replacement bung?
Guest loren
 nztintin']
[quote name='Optical said:
what about taking the whole rear cover off?
would mean removing diff anyway.... well i did anyway
why? it just bolts on at the rear.
Because the rear mounting studs that go through the rear subframe come out of the rear cover, not the diff casing.
To remove the rear cover, the diff must be removed from the car.
