Recommended Upgrades Turbo
Guest SPANKU
you guys do remember that hes got a ver4 wrx meaning that the inlet manifold is kinda different and its a b.i.t.ch to put a td05h in unless its been modify to fit a stright pipe instead of the 90 degree. if that makes any since.
a td05 will get you 240kw maybe. but i would get something bigger like a gerrit or something like simon c has, if i have the money
 Simon C said:
FP Green is good if you want to make more power than what a TD05 20G can provide. Although I'd rather have a Garrett GT3071R for that purpose.
interestingly the party i've been speaking to about the 3071 is good for around 260od.. i thought it might shoot further than that.
Not really, more tomato, potato. Totally different.
i.e. my turbo has a rather high boost threshold (~5500 rpm), but its not that laggy at all. If the engine is above the threshold and I am on and off the throttle, the boost response is instant enough for all intents and purposes.
What gearbox are you running?
With such a high threshold you would benefit from gearing it closer, but i suppose you wouldn't want to lose out on Top speed.
 BC5RA']
Its a mixture of parts using a late model 5-speed that I think was from a Forester (had an oil pump in the center diff housing and a code that I couldn't find on the google machine) and it had a 4.444:1 front and a 1.1:1 center. I swapped for an old center housing so I could use a 4.444:1 rear diff and so now the top speed is somewhere around 210-220kph at the redline.
The high threshold is partly due to the short gearing, if I swapped to 4.111 ratios, I reckon it'd drop below 5k as it would load it up more. If you left foot brake it while loading it up, can acheive full boost between 4.5-5k rpm.
