1999 Legacy GTB BH5 O2 Sensor
Hi all
I have owned my BH5 for about 18months now and has been great up until a couple months ago.
I have just had it into my mechanic and chucked it onto the diagnostics which came up with errors on the O2 sensor which was found to have a broken wire.
My question is: Is it possible to solder this wire back on with minimal disadvantages(?) or is it better to get a new one fitted off the bat? If the latter, do you know if it is 3 or 4 wire and the best place to get a decent one in auckland (west is preferable) as i was quoted $243+gst for the part.
They can't be soldered as the wire is stainless to resist the heat of the exhaust, and solder won't stick to it. Try crimping it maybe??
YOu can buy stainless crimps but you could always get a second hand 02 sensor if its the wire on the on the sensor. If its the loom wire youll need to crimp it.
Pull back the sheathing and have a look at how many wires you have on it. Dont the legacys have two though?
Hmm ill have to look this weekend.
i take it these crimps are available from repco or supercheap? do they need a special crimp tool or will a standard sparkys pliers do it?
you can solder stainless wire, have done it at work for heating plates in some injection molders, you just require the correct solder for it.
-smurff
 pl0x']
[quote name='Swindog said:
two beers can will suffice :) what ever works.
EH?
Pliers should do it? just crushing it together really
and if it doesn't work ill have one for sale soon
Meaning, whatever he has available for him to crimp it will work.
smurff
what sort of solder do you use? will it work with a standard soldering iron or would i need a special high heat one? cos that looks rather good right now
