excessive hand brake travel
inside of the rear hubs you can wind the little bezel up, (make sure hand brake isnt on). do equal revolutions on both sides a few at at time and test the handbrake. Ideally a picture is best to explain where this is, but it has a gromet over the hole on the inside face of the hub. The little bezel is bronze coloured and has thick lugs on it. one way to tighten the other to loosen :)
its a 1/2h job max and will make your h/b as tight as new :)
shoes usually just getting worn or some cable stretch id guess.
correct handbrake is drum, and it would take some epic forgetting the hand brake and driving round on it to wear it out...
just put it somewhere flat and have a look for the bezels (little windy things) as described... you will get it noice and toight again promise ;)
if i CBF il try get your a picture coz its piss easy to adjust once you know where the thingy's are.
 kingersman said:
yeah shhhwwweeet azzz, just get me a picture so I have a good idea
go have a look yourself anyway.. you will find it.
its horizontally mounted, and its a barrel shaped thing with lugs on it (is how you wind it up or down) and iirc its bronze in colour. The hole to get to it is behind the axle so its easiest to get at from the rear.
Youl need a small flat blade or similar screwdriver to wind it.. its quite stiff.
Pic tomorrow.
Guest boostcut
 JoKer said:
drum on disc brakes? (or disk)
yup pix way better - and IIRC isnt there an "in-cabin" method?
no no no no.
de-adjust the handbrake cable inside the car with a 10mm socket.
adjust the clickers in the shoes until it drags and back off slightly
re-adjust cable in car to a good height.
this is the correct way to adjust any handbrake
 boostcut']
no no no no.
sorry what???
Guest boostcut
what dont you understand about that sentence? you adjust the "adjustment" to spread the shoes onto the drum, to minimize travel. with a flat blade screwdriver.
haha didn't even know there was a different way... good thing that i've never had to adjust one on a car worth more than $500
Guest boostin
We always set the drum adjuster to full tight so you can't turn the wheel, then back it off 5 clicks/notches. Then adjust any excess travel from the inside with the adjuster nut on the handbrake lever. The lever should travel 3 - 5 clicks max when you're done.
