Greddy profec B spec II circuit diagram / PCB pics
Guest loren
Guest loren
 kamineko said:
GAH sorry for suggesting it was a capacitor. I now believe its a 2.5A fuse :)
actually i can't back this up. but it looks identical to a smd fuse used on a playstation mobo
hah... a blown fuse ;D
I like that outcome 8)
And possibly resettable as well? edit: actually don't think so... just seen a link about these being the most commonly replaced part on a motherboard.
Thanks for the help everyone :)
Guest loren
Why do you say 2.5A? how do you decode the number, or is it exactly the same as the playstation fuse?
Do you know where to buy them from?
i had a look online and havn't find any means to decode them yet. i'm only going on an identical looking device on a PS2 motherboard.
the resetable ones are usually flat, and it would have already reset when it cooled down
infact i wouldnt mind desoldering one and posting it, i have a bunch of old ps2 mobos
Guest loren
 Optical said:
best hook it up without the fuse, see how much current is drawn, then get a fuse rated a little bit higher than normal operation :)
Someone at work said it would need to take largish spikes (from the solenoid) so should be rated quite a bit higher
than the amount of static current... but also should be a slow blow type fuse, also because of the spikes. The spikes
themselves would be dealt to by the diode and a capacitor. make sense?
yep to all that, you might be better off working out the current actually from the solenoid resistance, the current drawn for a fluctuating voltage can be hard to measure without a scope. I assume it's a 12V peak voltage fed to the solenoid. If the solenoid is 300 ohms (for example), then peak current draw is 40mA at 100% DC
Guest loren
So finally got round to replacing the fuse... I had 10 arrive a few weeks ago (minimum I could buy).
The new fuses were the same width and diameter etc but only a mm high, so needed tweezers instead
of pliers to put it in place :) I thought it was going to be a difficult solder job, but was really easy... whole operation of removing old fuse and soldering new, took less than 5 minutes.
Went for a test drive this morning, and it's working again, so the fuse was definitely the culprit :)
If anyone needs a fuse, let me know.
  • 5 years later...
Hi,
I know this thread is super old, but my Profec B Spec 2 is not working as well. Could you please tell me which component on the circuit board you replaced? Perhaps circle it from the picture of the circuit board on page 1.
Thank you kindly!
  • 5 months later...
This is the one i found, i assume its the fuse current that is important not the voltage rating. So this fuse will work just as well?
FUSE, SMD, 5A, 0603, SLOW BLOW
Voltage Rating V DC:32V
Fuse Current:5A
Breaking Capacity:50A @ 32V DC
Blow Characteristic:Slow Blow
Series:SF-0603S
Fuse Case Style:0603
SVHC:No SVHC (16-Dec-2013)
MSL:-
Packaging:Cut Tape
Voltage rating just has to match or exceed whatever you're using it for.
Check that the case style is compatible, earlier in the thread someone mentions a 1210 style case but 0603 is probably near enough unless the solder pads are tiny.
I hope you have steady hands, soldering SMC sucks if you haven't done it before.
