17x8" p50
Should be fine. +50 offset is quite high so they wont stick out too far (might pay to check the inside clearence to your strut with offset that high), but I would advise rolling the lip up on your rear gaurds if it is not already done. Shouldnt be too much effort to get them to fit anyway :)
I have +48 17x8" on my Sti, you will probably have to roll the rears a little, fronts should be fine. You might struggle for shock/spring clearance if you are on the standard shock/spring size. Mine clears with the coilovers with lots of room but would probably need spacers to fit a car with stock style suspension with the extra width.
