4pin tps converting to 3pin tps
hijacka
Hi there
Im hoping 1 of you can help me out with a wiring diagram of a 3 and 4 pin tps. Or maybe someone has converted from v1/v2 intake manifold to v3/v4 and still using the old loom aswell and knows which coloured wires go were...any help would be much appreciated..
Thanks i advance.
 liquid_ice said:
Use the search next time
http://www.northursalia.com/modifications/misc/wiring/wiring.html
There are heaps of subarus listed :)
Yeah heaps listed but non that can answer the question i asked.
There is a chart there for a 3pin tps that has wiring colour codes that i already have but none that specifies a 4pin tps sensor and there colour coded meaning.
Surely there must be someone else that has upgaded to a v4 manifold that knows which wire goes where..im pretty sure i leave out the brown wire on the 4pin tps but dont wana take any chances
Thanks for the link anyway liquid ice..but unfortunatly your still a 'Nob Jockey'lol ::)
 caged said:
What ecu are you using to not need the 4th wire (idle switch)? I put a v4 manifold on my V2 but I just used the v2 tb with a few mods.
Hi caged, im running a possumlink ecu, its in a bf wagon and have recently switched from a tdo5h to a vf22 and i have bought i v4 intake with throttle body etc. Didnt wana twist it because its running a nice divorce downpipe etc, hoping that someone here would be able to tell me which coloured wires go where as i dont have a multi meter to confirm which is 5v/ground/ signal etc.
 hijacka']
url]http://www.northursalia.com/modifications/misc/wiring/wiring.html[/url]
AWWWW you make me all warm and fuzzy!! we can be nob jockeys togther!!! :-* :-* :-*
I think you are right bro, on mine I have left out the brown wire (forget what I pm'd you before, that was what I was originally told to do but it was wrong haha) mine seems to run fine, it threw a code for the idle switch when I plugged in a factory ecu to try it , but doesnt affect how it runs at all
im pretty sure the resistance is around the opposite way between the two as well, ie: you wire the earth wire from your bc/bf loom to the 12v wire on the v4 tps, and you wire the 12v wire from your bc/bf loom to the earth wire on the v4 tps, signal (white) stays the same, and brown on your loom is not used, thats how mine is wired, I cant remember exactly where I got the info from but it seems to work haha, except for throwing that code for having no idle switch (which is the un-used brown wire) but doesnt seem to affect it at all
 zarnah said:
Your the man ryan thanks heaps!!!
i thought it was black to red aswell, looking at that pm of the v1/v2 tps sensor diagram i sent you
but there was a little voice that said warning do not try it lol..but im going to now once i get some rails this week..cheers bro!!
Will post up results soon ;D
  • 2 years later...
