OLD Dyno Leaderboard Top Twenty
  • Replies 339
  • Created
  • Last Reply
Top Posters In This Topic
Top 20 dyno board.... Umm suggestion to consider
Can the fuel used be stated with all top 20 ?
Pump gas , C16 , methanol etc
Also if road legal or not and state what the use is , ie drag / circuit
 nt_a_foz']
[quote name='xecuta said:
Thanks I wonder what I get at 22psi ?
Be suprised if they can push it to 22psi man the turbo will run out of puff by then id say.
Mine was pretty much topped at peaking 20 odd psi.
Same here. peaks at about 21-22psi at low revs and comes back to about 20psi fairly quickly and holds right though at 20.
that isnt too bad though... thats just 2psi drop... what ever it is, is better then 15.6psi. VF37 is tempery at the moment til the IHI RX6 is getting rebuild
car is getting retune tomorrow with the new MAF pipe being machined out from 65mm to 72mm. the AFM is also been replaced same as new iridium plugs... was going to use platniums but im alway been happy with iridiums
Ive heard iridiums are better than platinums anyway? I could be wrong though
  • 3 weeks later...
chucked car on dynopowers dyno other day bit over 190kw at 6000rpm on 12psi air/fuel went all over place after 6g any advise got bosch 044 surgetank etc. relatively standard dsr turbo extractors full 3"stainless exhaust hdi boost controller. getting link storm in nxt couple weeks will this stop problem? wit put slip up soon
 maserati mick said:
190kw @ 6k with 12psi thats exactly What im after what engine model and ecu
v4 sti as far as I know don't know what computer is in it haven't checked will be ditched for link shortly bring on 200kw+
 rskikn said:
Make :subaru
Model :legacy RS
Year:1989
Name of Dyno :speedsource
Date of run 01/06/2011
299kw@25psi on 95oct no nos no race gas.. standard gtb heads.. gt3082r garrett..
good effort, nice to see a BC5 doing well :)
 rskikn said:
Make :subaru
Model :legacy RS
Year:1989
dyno plot?
gtb heads as in bg5(pre 98) or bh5?
 pl0x']
[quote name='rskikn said:
Make :subaru
Model :legacy RS
Year:1989
dyno plot?
theres a pic of it in the what have you done to your car today thread... sum where... lol... 96 gtb.. dont have a scaner..
Make :subaru
Model :legacy B4
Year:2000
Turbo: MSE TD06/05 20G
Fuel: BP98
Engine: V4 STi fitted with Kelford cams
Name of Dyno : NZEFi
Date of run 21/07/2011
Power:231.4 @ 19psi
Torque: 360.6 Nm
Will update with dyno sheet once I get my hands on a scanner
Watch this space, will return with even MOAAARRR POWWAAAARR haha (but not anytime soon)
 B4 2000 said:
Make :subaru
Model :legacy B4
Year:2000
Fuel: BP98
Power:231.4 @ 19psi
Torque: 360.6 Nm
Woah that's nice! Your car must be quite quick hahha. Loving it! B4 all the way hhaha.
 B4 2000 said:
Make :subaru
Model :legacy B4
Year:2000
Fuel: BP98
Power:231.4 @ 19psi
Torque: 360.6 Nm
dam that elmo chick is distracting!!! takes me ages to read anything you post hahahahahahaha
 BF5GT90']
Make :subaru
Model :legacy RS
Year:1989
hmmmm... good effort... wtf?? lol 299kw@ all 4 in a dayly driver.. lol :o
 kwi_fozze']
+1
You click on his name above it, then on the image, right click and press view image.
 Lampard']
+1
sweet.. its now my csreen saver lol :P
