Bonnet gas struts
nickmcgill
Another idea? You can get gas struts from Commodore bonnets, models VP onward, and they have very heavy bonnets. The fitting for the engine bay end is a little chess pawn looking thing that would go in place of the bolts holding the guards on. Then you could just weld the other ends onto the bonnet, could be quite easy if you knew how? I got mine for my Commodore for $20 for both struts, and all the connectors for both ends.
  • 1 year later...
[table][tr][td]STTO3680.jpg[/td] [td]STTO3680
Gas Strut for Tool Boxes 305mm [/td] [td]$25.05[/td] [td]each[/td] [td]
[/td] [td]
[/td] [/tr][tr] [td]STTO3700.jpg[/td] [td]STTO3700
Gas Strut for Tool Boxes 470mm [/td] [td]$32.20[/td] [td]each[/td] [td]
[/td] [td]
[/td] [/tr][tr] [td]STTO3720.jpg[/td] [td]STTO3720
Gas Strut for Ute Deck Canopies 520mm [/td] [td]$40.25[/td] [td]each[/td] [td]
[/td] [td]
[/td] [/tr][tr] [td]STTO3740.jpg[/td] [td]STTO3740
Gas Strut for Ute Deck Canopies 800mm [/td] [td]$65.55[/td] [td]each[/td] [td]
[/td] [/tr][/table]
catalog in my hand says last one takes aprox 50kg of force to close, and all the others 20kg
