Gutting catalytic converters?
Nope your probably thinking of the heater element in the oxygen sensor (lambda sensor). My 96 gtb only has one oxygen sensor and AFAIK the second oxygen sensor came in when cars fully switched to obd2 though in saying that not all cars have a second one to check if the cat is working properly
V7 have a o2 sensor past the cat and it's only there to check the efficiency of the cat
Removing it brings a code Altho can turn it off and it's gone
Does not affect performance at all
Maybe different for other models
Anyway if u decat v7 and keep sensor it does got bring any check engine lite or does not even report a fault in the diagnostics
Makes me wonder why the he'll they had it lol
Applies to jdm v7 and Nz new v7 as have tested on them 2'models only
I suppose I could just disconnect the sensor on the second cat, and see if it throws a code from being too lean or under temp, but then I would need to reset the ECU to remove the check engine light.
Can you just disconnect the battery for a time, or do you have to go see the local subaru agent? I'm not a fan of Winger's subaru here in Hamilton!
what car have u got?
  • 3 weeks later...
 pappu']
97 Legacy GTB Limited
Its just a temp light, it has nothing to do with the ecu and you dont need to disconnect the battery. From memory they only light up when they go to ground so just leave it unpluged.
