Steering shudder only turning left ?
  • Replies 63
Man thought I had it sorted but this phantom shudder keeps haunting me ! I thought the ball joint was the cause . All though the shudder is allot less now and not so harsh its definitely still there . . Am going to check left wheel bearing when I get back from work trip . . Sure it cant be the struts ? ? As the struts have seeping seals and knock a tad.. On saturday I also loosened right cv nut and slid inner cv in and out and it reaches both ends easily ? Could it still be this though ? I might as well through my other axle in when I get a chance
Since my right inner cv does slide in and out freely . . Can it be the fact there is excessive wear in the race in which the balls run in ? Would that cause shuddering ? When I had cv nut off I slid inner cv in and out and seemed ok I also turned the wheel and slid in and out . . . . But all I can think now is the tolerance is too great
Struts wont cause a shudder
It will have been the axle inner joint
Pull it apart and inspect the outer races, I'm sure you'l find wear marks in the races
99% sure your set up will have the three roller (tripod joints)
They are case hardened roller and I am yet to see one fail
The wear always has been in the outer part of the joint
Let me know how you get on
Rick
the shudder is from the axle joint not being able to slide in/out and the rollers/balls are held captive - under load
This induces a sideways vibration/shudder into the engine /trans
