Dumb Question Thread!
Jambun
 BlkPnthr']
Hence posting in the DQ thread.. so does it pop out forward and sideways from that bit of the seat? Fiancé wants to know for baby seat placement..
Yes it pops out forward, driver's right shoulder/arm, front passenger's left shoulder/arm!!
Like this one here www.youtube.com/watch?v=U-hF4XqEBHQ
[quote name='clintondane said:
Whoa, way too much aggro in that response Abdul. ;D
not really ? it was the simplest answer!! sorry if my reply seemed a bit aggro :)
Intermittent (very) lumpy idle, missing under load on a 1998 WRX, check plugs, leads and AFM?
Also it has gotten progressively worse, used to be the odd miss from time to time, now quite a bad miss. Plugs have never been changed since engine was built about 60k ago.
 Stoffa said:
Im about to out a baby seat in the front of my coupe, I've only got steering wheel airbag though
How old is your baby?
if less than three then it's probably better to have your baby facing backwards! facing backwards is safer than facing forwards -just something to keep in mind-
check plugs and coil pack?
 BlkPnthr said:
Is it possible to install longer seatbelts in the rear of the car? The current ones are too short to use to strap in the car seat we have. Either that or extenders but don't think they're safe
Easy answer is no :(
we had this issue with our rear facing capsule as well ( in an Audi) it was very tight but we could get it to fit.
extenders seem to be safe and well made, what I have done is I made a steel extension to move the clip bit out a wee bit
I just replaced my main bulbs with philips ones, and i also got the side marker lights in the packet. I can't find any info on how to replace these smaller bulbs? Do I need to remove the whole headlight to get at it?
 G-unit said:
http://www.trademe.co.nz/Browse/Listing.aspx?id=494129979&permanent=0
this the usual price for these? want a genuine 1 when i do oil change, kind of a dumb question :D
That's about right, somewhere between $24-26 iirc. But if you're paying shipping on that then it's definitely going to be more expensive. Assuming you live somewhere where you can buy it in person.
  • Guest locked this topic
