Dumb Question Thread!
Jambun
 sti555 said:
sorry to sound silly but do you mean with the diameter or the profile will rub.the car use to have 215 35 r18 before i went 215 35 r17
Width of the tyre. Might be close to rubbing on either the inside of the guards or the strut (or both).
 B4 I was 250T said:
Dumb question, how do I depressurise the fuel system in a 1999 B4? Where's the fuse I pull or what do I need to do? Cheers y'all! :-)
Pull the bottom relay out - did this to mine the other day - B4 have a fuel pump controller in boot as well (left side near screw jack mount)
Edited by B4_685
nah it doesnt do it at all when cold only when i give it abita boost as soon as i tap accelerator it comes back up to 800rpm ish and idles sweeet. also overboosting still happens only on cold start when warmed up it doesnt overboost and cut,
probably depends on your fuelling and tune, and what you've done to your engine and if it can handle that much boost day-to-day.
Since you have the VF34, it might be different but I think stock boost is around 18psi.
edit: Typo
Edited by Richwalk
Since you have the VF37, it might be different but I think stock boost is around 18psi.
Except he has a T518Z and decapped injectors and a larger fuelpump and the ECU has been reflashed ;)
  • Guest locked this topic
