Dumb Question Thread!
Jambun
yeah I hope so, have had a crack with some of the turbo defs for the 2009 spec c before they were released and got a few maps out of it, we'll see how we go hahaha
its post v7, its si drive which points to canbus, it will be reflashable. just need to work out how to do it...
bonus being I have a tactrix 2.0 cable, a vagcom, and a bt wireless unit. have btssm on my phone and about 4 different tuning programs on the laptop. something will work hahaha
Also matt from kido_tuning. Sounds like he's fairly good at hacking things together to get you running if the defs don't exist for your ECU. Imagine you'll be wanting to have a go at tuning it yourself though right?
Can get some pretty awesome results if you go with e85
 Marky said:
In the same vein - do BH5 front braces fit anything else (and vice versa) - I want one
They fit the model before, whatever (BG?) that is, because that's what mine came off.
And I think the same year's WRX's, but don't quote me on that.
Seems to be hit & miss - some can flex enough to fit, some not. Weird
Next question - does anyone know where in NZ I could find a "hobbs switch" - or anything like it - need something which can reliably and consistently activate a relay at 10/12psi or so
Found one which isn't adjustable & would be good to have that facility - hell even an oil pressure switch would work if it was the right PSI I guess
 megamac']How does one hook up a two port BCS?
Using factory TT one on single turbo swap. Just need to know what vac line goes where and all the t pieces and what not :)
[quote name='Marky said:
Turbo outlet -> restrictor -> T piece, inline leg goes to wastegate, teed off line goes to BCS, outlet of BCS goes to intake pipe or atmo if that's not an option
Couple of pic's if it helps. Turbo end, paint dot is the restrictor pill location:
img]http://s25.postimg.org/8whj7yejz/restrictor_paint_dot_001.jpg[/img]
Then at the BCS, hose #23 from the turbo/T-piece going into the solenoids side port. Then the hose #10 recirc/bleed from the bottom port on the solenoid:
  • Guest locked this topic
