brembos
On the topic of Brembos -
I'm currently running Brembo front with GDB 2pot (non Brembo) rears, using an adaptor to suit the rear end of my BE Legacy.
These ones: IMG_20101030_223539.jpg (not my pic)
I'm looking at fitting a set of rear brembos to my car. Is the adaptor for those^ 2 pots & Brembo rears the same? The Brembos in question come with those DBA conversion rotors (5x100, smaller handbrake shoe etc to suit 160 rear end).
Thanks.
  • Replies 53
well anyway. ive managed to buy the 2 pot rears and some normal 4pot calipers and i bought some brand new znoelli slotted and dimpled rotors and pads al round ...cheers for all the help guys.
1 more question relating to the 2pot rears/Brembo question on the last page -
Do the brake lines use the same connection at the caliper?
Thanks/
 funkytown said:
it hasnt been answered yet but the brembo rears wont mount to your rear calipers. im fairly sure you'l have an R180 rear end so you require the r180 rubs from a v5/6 sti (that had 2 pot rears).. or v7/8 sti rear hubs.
the fronts mount right up.
good luck with wheels as above haha. I also have three sets :P
i got a ver4 sti type r
it fits into 100% front and back apart from the skid plate which needs to be hammered flatten or removed which i did
as long as your hubs are R180 it will fit ( if it has 2pots as funky said)
btw your type r v-limted isnt a STI is just a poor man version of a turbo coupe
Thanks/
answer is Yes. all the break lines are the same
 funkytown said:
note still if your putting the rears on a BE legacy the rear hubs require adapters :)
my mate can make one up for $100.00 plus shipping if anyone needs it
To bolt to the calipers? I have some that I'm using atm with the 2pots which should work with the Brembo rears (see previous page)
 xecuta']
I am keen! Will these fit in a BE5 2002 Legacy RSK? And what else do I have to change (rotors etc)?
I am after the rear adaptors to put Brembos in my BE5 02 Legacy.
Where can I get the adaptors?
What else do I have to change?
 WRXONP said:
does the coupe have a r 180 ?
only the STI coupe gets R180... you also get the JDM V-Limited ones ( with the roof ventvf22 )
 LAZLO']
[quote name='xecuta said:
to change the back hubs you will need to change the drive shaft and diff also
thats abit of work for me to do lol
2 hours max... depending on the amount of beer before and during... hahah
