DIY split fuel rails Reply #3
  • Replies 117
bro... check out my fuel set up next time, i modifyed the standard fuel pressure reg and used the factory left and right rails, works a treat...
  • 2 months later...
i can make you some if you want, i put a for sale thing up a while ago. i do this sort of thing for a living too if your worried about dodgy-ness
Can you put pictures or explain how to do this please?!? ;D
I have seen this http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Subaru/Engines/auction-236666695.htm but where do the fuel regs go/what do I need?
yea the fuel pressure reg goes inline with the "return"from your rails. you can use your fpr i just cut the end off a rail and made a fitting up to suit, if you want i can make one and send to you for $40 give me a call/txt if your keen and il do it today 0272935871
  • 3 months later...
Im part way thru this (and a few other mods) and im wondering what happens to the breather line or what ever it is 3rd fuel line near fuel filter- not fuel in or return, also there is 2 vac lines in relation to the fuel setup one is vac for the Fuel pressure reg and the other is on the throttle body, what happens to this line, can i just block it up?
CHeers
the third line is purge canister which goes to the green solenoid. Its safe to leave off. The vac lines NEED to be connected otherwise you wont get any fuel. Make sure that you get a t piece and tee the two fuel regs together at exact lengths. (read: the lines from each reg need to be the sam distance ) This same distance applies for your fuel line too. Make sure the lines are the same distance to the tee on both sides. This mod is parallel so hence why the equal distance rule applies. Hope this makes sense hard to write from a phone! Cheers chris
Cheers, explaining stuff over the internet dam tricky sometimes....anyways....
on the throttle body there is a vac line that goes to steel lines and then to the carbon canister, which is removed and the vac lines are just joint up making a circuit for want of a better word - can i just block this line at the throttle body?
I cannot see any green solinoid....altho we might be talking two different cars....
The other bit i have issues with is what do do with the other fuel line it comes in from the bdoy near the fuel filter, three line one is in one is retun...what is the other one?.... can i just tuck it away or does it jsut need to be blocked etc,
 dubbedup']
Yeah it is. Where about are you located? Maybe I can help you do it?
Yeah you can. Doesnt really do much but get in the way and stop emissions when the car is warming up or something like that
Lol quite possibly although they are mostly the same
Yep tuck it away or just leave that line dangling. As said its not very important
Here is my diagram on my site that should be fairly helpful url=http://car.chriswiggins.co.nz/Parts_and_Modifications/split_fuel_rail2.jpg]http://car.chriswiggins.co.nz/Parts_and_Modifications/split_fuel_rail2.jpg[/url]
Blue is fuel in, Red is fuel out and green is the vac lines onto both the fuel regulators. When I did this I thought fuel in started at the regulators but it doesnt. Fuel out is from the regs.
Make sense? :P
