is it okay to drive a short distance with the ic off?
If Its one of the newer models 2000+ then u won't even need to connect the turbo to the intake throttle
Just remove the wire from the Maf and it Wil run fine
The ecu's have a fairly half decent Sd mode setup so will revert to thT and drive ok
On older models the Sd mode is no as refined but it will still run in Sd mode
Basically with afm unplugged the ecu will run in Sd mode with check light so u can Essentially run with throttle open and not connected to the the turbo
Just nana it along and get sorted soon eh
 ADIKT said:
When my reducer popped off the throttle body my powerFC noticed the sudden pressure drop it shut the engine down... Happened twice actually.... Personally i wouldnt drive anywhere with out it connected
powerfc is not smart enough to support sd mode normally (unless specifically setup i been told)
the stock ecu had coding to support that and will run the car in rough mode without any connections as long as afm is unplugged
the newer ones have a better coding so not as rough..fairly smooth ish
why on earth would you want to run it with no intercooler if your not going to plumb anything up to throttle ? you'll be sucking in dust which with score the SHIT out of the bores and rape the rings . . . least you could have plumbd maf and air filter up to throttle body and a air filter
LOL i would have just plumbed it up to go get some.. or walked ??
 pappu said:
its not a boost leak if afm disconnected.... ecu runs in sd mode so wont know abt the leak
will drive like sick but maybe in certain urgent situatuions its necessary..perhaps..
hmm.. the ecu wont know how much air is going in.. it wont know how much fuel to add.. it wont know how much load is on the engine...
long story short people must look at cars differently.. i would never do such rangi-ness but none the less OP has his shizz sorted..
all though the time it took you to get on the forum and post up etc you could have just slipped it back on !
subaru ecu's support sd mode
its basically a rough rough calculation on how much load based on
intake air temp
throttle position
map value
rpm
rate of change of parameters
anyway its a rough mode thats on a backup map table.. in the event of maf failure things can still run in a limp home mode sorta thing
wont kill the engine for small distances and just nana driving will get most cars home/workshop so can change maf
i suppose thats the reasoning by subaru ppl..lol.. maybe other models have it too..i dunno.. i know my mazda6 does..
anyway yea man i do agree on the no filter bit u posted.. i suppose in some certain urgent situations it cant be helped
