half a clutch?
Joker
I am experiencing what I believe is a worn clutch (this will be my second new clutch in this car)
pedal only returns half way on travel and I need to sometimes pull it up with my toe etc
fluid is topped up and I am putting it down to clutch dying
OR is there anything else I need to check?
drives fine otherwise : slight graunch into 1st on occasion
  • Replies 92
 rex-leggy said:
i had this on my wagon to . do you have the spring on the clutch fork still?
its right next to where you get the clutch pin out.
it helps the pedal return.
+1, this is the common fault when the pedal doesnt return esp at higher rpm
other wise a bleed and pedal adjust
omg i have ust experianced the same thing in my car last weekend. went to hamilton for wnagnaui and when driving around town my pedal did the exact same thing seems to be when the car gets hot aswell like sitting in drive threws it will do the same thing clutch feels different and first time ive had to pull pedal up with toe.
So wat are you guys thinking of looking at?
and I thought i was starting a useless thread...
reason I associate this with worn clutch is last time this happened it started to slip real bad afterwards : maybe they simply fixed the spring when new clutch was installed :P
I had this issue on dyno. They blead the clutch multiple times and upgraded spring and still happened.
They eventually put it down to the bearings in the engine being warn and the crank floating. Thats what they said, I cant really see how that would effect it that much but they seem to know what they are doing when it comes to it.
 rex-leggy said:
yea some high kms subi engines have wicked end float!
i took one apart and it was using the crankcase as a thrust surface :D
pull clutches put alot more strain on them the push ones
what did you find joker?
Endfloat :( thrust bearing ate 1.5 mm out of my crank on my Old engine
Sent from my GT-S5570 using Tapatalk
  • 3 weeks later...
Almost sounds like your clutch fluids boiling ??? Try wrapping down pipe and put heat shields on?
