SSI Headers
sl8r
I dont have the SSI headers, but try looking up Kakumei headers etc, you will see they are actually identical, also identical to the genuine tomei headers. I have one myself, cant fault the quality. welds are beautiful, piping is nice and beefy, the joins are also very very well made, mating surfaces are 100% flat, fitment is good and so on.
The only thing I had to do with my car was notch out a tiny bit from the chassis where the headers were rubbing under load.
 Ninja 8)']
[quote name='sl8r said:
wow looks sexy!!! 850 for an exhaust manifold!! performance cars for you!!!
no tight spencer for you :P jks lol.
Yep thoes are the ones I have used before, good mani I say. Nevr pushed huge power thru them but worked well and never did me wrong so cant complain. Sounded still nice and subby like too
lol. Might want to make a custom header gasket for the tri bolt flange then as mine came with a perferated type gasket. Make one out of thin copper sheet or similar.
It worked fine but my EGBP's werent that high compared to what youl be runing with the boost and flow to achieve that power level. Just my input for a heads up to save one of thoes annoying things on the dyno day lol.
Mind you they might of got smart and started selling them with a MLS up pipe to mani gasket from new now as I bought my set a little while ago but yeah just my thoughts lol
 ADIKT said:
Ive got some syms headers for sale. Already heat wrapped!
Yep seen those, but want to twist the setup and will be harder with the symms ones as there is no up pipe. And I don't want to sound like a Honda ;)
ssi make a few different types, the good ones are really good, theres an unequal length set they sell for about $900 retail that has a 3 bolt up pipe flange.
you can spot a good set by the qualitly of the welds on the inside of the collector, good sets have a nice evenly spaced spike at least 25mm long, this helps creative a venturi and helps scavenge velocity from the highest flowing exhaust port
