v3 and v4 sti ecu
Pappu1
The ECU's are different though. I do believe the V3 is the more... aggressive, of the two. Or at least i've been told...
I'd love to try both and see just how different they are from the drivers point of view.
 funkytown said:
yes interchangeable.. V3 STi usaully 6s and v4 is (i think)8s.
negative. V4 STI / STI RA / STI R are all ecu code 75
they do share the same pinouts, pretty sure they are interchangable but its the one thing i havn't tried yet. i think the boost solenoid plumbing is different. not sure if its important
Im told the tune between a ver 3 & 4 sti ecu is different.
The difference mostly down to the slightly more agressive cams on the 3. The p20 exhaust housing would play its part as well in the need for a different tune.
as far as i read around it seems the v4 sti has slightly more torque and drivebility so tunes must be slightlly diffreent -
on the USA forum there was a thread saying that the type RA had a lower tune than standard sti based on its shorter gearing
not sure if that was true for v3/4 or only v2
 kamineko']
75... or 7s (7S)...?
lol. i have spent a lot of time researching these codes. trust me :P
no formatting. i still have to tidy this somehow for it to display right on the forum
Ver3 GC8 D WRX MT 1S AC721 * D55 AFM: E AA271 MAP: AA090
WRX AT 3S AC740 D34 AFM: AA280?
WRX-RA MT 1S AC722
STI MT 6S AD170 D35
STI-R MT 6S AD170 D35
STI-RA MT 6S AD170 D35
GF8 D WRX MT 2S AC730/1 * D31
WRX AT 3S AC741
STI MT 6S? ?
Ver4 GC8 E WRX ? 7S?
WRX ? 8S? AE380
STI MT 75 AE360 * D66
STI-R MT 75 AE360 D66
STI-RA MT 75 AE360 * D66
22B MT 95
GF8 E WRX MT 88
WRX AT 8Z
STI? ? 8S?
ok so the question also stands is which ecu would be aggressively tuned for performance etc.... v3 or v4? so i can decide which one to go for , for my v4 wrx... was thnking v4 sti type r or ra, aparetly no difference between both of them so yea ....
I would say, if you had to chose between V3 and 4... def go V3 6S
I've got a 6S in the GTB, and it's brilliant. Compare it to the old TT ECU, and it's just liberal with the petrol, crackles and pops everywhere, it's a mean driving experience.
Dunno how it stacks up to the V4 one, but what i've heard is the V4's a bit more tame.
Yeah, i'd love to get a hold of one and see. Till then, all hearsay and ponderings
Only comparison i do have is between the 206KW 3 Plug GTB ECU and the 206K V3 STi ecu. The GTB one was soooooooo boring compared, i never heard a crackle out the exhaust with it.
oh. this is your black wagon i was following out of taupo? that had a 6S in it? you or Shale did put the hammer down at one point?
well lol its allllll down to weight. 6S or 75 isn't going to make a massive difference. much better than V1/V2 tho ;)
STI ecu is always going to be the most aggressive. but an ecu is tuned to a particular engine.
v3 / v4 engines are essentially the same, however its generally said the v3 has more aggressive cams. and they run slightly different turbos.
so you can assume the v3 ecu is tuned around this. how well the v3 or v4 ecus work with slightly different cams is anyones guess.
  • 3 weeks later...
 ReubenH']
[quote name='kamineko said:
Ver3 GC8D, WRX, MT, b]1S[/b] AC721 * D55 AFM: E AA271 MAP: AA090
Bump. And can someone confirm that this ECU runs grey tops and a purple AFM?
negative, the 1S or IS runs yellow injectors and Orange AFM. its the bad boy jdm wrx with vf22 and 280ps
your thinking of the 2S which is based on the EJ20G
