PLEASE HELP
ok so my car started coming up with the check engine light so i checked codes
came up with code 23 which is afm so i replaced it
now it is coming up with code 22 which is knock sensor and code 12 which is starter switch
my question is has anyone come across anything like this before? and if so am i just going to have to keep replacing sensors till its fixed or do i look at trying another ecu?
any info will be muchly appreciated
Also have code 12 (and 24)
I cannot find anything Googling on how to fix starter switch. Only cel codes and how to clear. . . . .
Cleaned out ICV to fix code 24 as recommended, it wasnt dirty really, and still get code after clearing.
Where/what is starter switch and how do we fix/clean/service/replace??
wont run without it will it? unless you pull it apart and flick wires...
just offering advice often genuine people refer to starter switch as the part im talking about.
try ringing genuine and pricing the part to fix the fault and finding out what it is.
i had a mate check cel the other day while i was doing something else when i knew afm was down. he got 22, 23 and 46 unsure how i just got 23 lol. double check and make sure not saying your eyes are shit... ;)
 rex-leggy said:
alot of time when a afm code comes up it will bring others up with it . after changing the afm did you reset the ecu?
^^^do this^^^ then try again
did you find out what the part was?
