Brake issues
Thanks Cuddas, will try that before the swap of lines.
So just to be clear, clamp all 4 lines at all 4 corners, if all solid then this rules out master cylinder being the issue?
Then clamp one line at a time and check pedal feel?
Or having all 4 clamped and releasing one at a time, e.g 3 clamped check pedal feel, 2 clamped check pedal feel and so on?
Thanks for your help so far
(I will clamp on the rubber hoses and NOT on the new braided ones as advised)
Yes release one at a time, does pay to do this a couple of times,
as to brake pedal feel while bleeding, if all are in good condition - when bleeding the rear brakes you'll feel the pedal will only travel half way down & not too the floor. this is fine as its just the first half of the master cylinder activating for the rear calipers, & as for the fronts you will notice full pedal travel to the floor, which is also normal,
it only takes a small air bubble too, to cause a spongy pedal & there are also a couple of subtle ways/tricks to bleed brakes even stubben ones, but remember its not a race & its not finishing off the missus's ;)
also while bleeding ive heard its a good idea to keep the bleeding container higher than the caliper. not too sure how much of an effect this would have though :-/
Maybe and only maybe if you are using one of them one man pressure bleeders then this will help,
normally wont make any difference :)
Haven't got around to clamping lines yet but will look to try this out this weekend. I am hoping it is the lines, then I can fit the braided ones and be done with this pedal feel issue.
Update (so will my brakes sorted for now)
"From we are borg"
Ok next step is how does the brakes feel once the pressure comes on, do they give a hard pedal or is it still spongy
if still spongy then I would have a close inspection for leaks.
if hard I would have a look at the pedal stroke adjustment
Okay so clamped the lines and everything seemed fine from a master cylinder and caliper point of view. Lazykiwi and I went about changing to the goodridge lines and another couple of bleeds using motul rbf600. Also lazy kiwi made some adjustment on the pedal stroke which was a couple of mm.
Much happier with the brakes. The brakes seem to come on earlier in the pedal stroke and are stopping a lot harder. Lazykiwi had driven the car before the above and thought the brakes were good.
From what I have read with other forums to do with pedal feel, a lot of people have said subaru brakes have more pedal travel compared to other cars like Toyota's or Honda's. I guess I was expecting the same pedal travel.
So if anyone else is doing this here is a summary and approximate cost just to give you an idea and for me to see how much I spent (and this is mostly just the front brakes)
-Front 4 pots second hand $200
-Genuine Subaru seal kit for 4 pots from Winger Subaru Auckland $65
-Genuine Subaru Cross Springs x 2 from Winger Subaru Auckland $103.50
-Cusco master cylinder brace/bracket $177
-Dba650s slotted front rotors - $412
-Average trw brake pads - $90
-Motul brake fluid rbf600 $30 per 500ml bottle
-Goodridge brake lines $199
Thank you to everyone that commented and contributed.
