 evowrx said:
Just buy them thro partsouq theyre far too cheap to muck around with.
But but, I wanna get all ghetto on it!
I have an idea, as you do sometimes when you is an injuneer, just want to know if its feasible before pulling the car to bits.
 evowrx said:
Not worth it. I was going to get some brass ones done but genuine thro partsouq are worth feck all.
I was thinking lube impregnated bronze, getting all fancy pants on it, plus I can get them cheap, and this week, which is handy.
Prob have a spare couple of linkages i could measure up/throw your way. Remind me tomorrow night im low on enthusiasm to go parts digging tonight.
Sweet as dude!:cool:
Y we no have like button?? I like this very much!
Man greenlane winger had me bent over backwards when I got quoted for these bushes some thing like 200+ I'll post a pic of the quote when I get home fokkin assholes only went there cause Partsouq had no cam shaft sensors so I thought I'd get them at the same time
I'm guessing in 5th at WOT you're doing like a buck fifty at least. Probably **** balance in the output shaft or one of the universals getting tired and it only shows up when the road speed gets high enough.
See if it does it at the same speed in 4th or 6th.
  • 7 months later...
It seems like Subaru's tend to have sloppy shifters across the early to late 90 range. I recently reverted back to the R160 ty752 v4 STI box where i decided to get a new shifter because mine was like stirring porridge. Picked up an OEM from Roscos who are located in Ashburton for $40. Shifts like a dream now. Swindog, did you notice it to feels significantly tighter by installing an aftermarket one compared to say a perfectly fine standard one? Just curious if aftermarket is better.
  • 1 year later...
@Induced - going back years now from memory but it made a significant difference, in saying that it was very sloppy to start with. Tighter to shift and zero movement. I think it was the cost was cheaper for AM vs a genuine part. And the fact I had some cash and was mucking around.
    574.7k
