How to bleed a clutch
sylus
about to do this - Keltik Will pop in soon and give us tips
remove TMIC to access Slave cylinder - and I assume similar to brake bleed process
replacing the TMIC is the hard part - allow a whole afternoon 0 but can be done in 1/2 hr if you know what and where to squeeze etc...
Theres more than one way to do this, but this is my method. You can use a similar practice to brake bleeding but thats hard if you dont have a G-Clamp and a good assistant.
Step 1. Bang head off wall repeatedly
Step 2. Find a partner who understands the concept of brake bleeding
Step 3. Remove intercooler and any other crap that happens to be in the way. 10, 12 and 14mm sockets needed here.
Step 4. Fill master cylinder with fluid right to the top - do it now as shortly your hands are going to be rather full
Step 5. Remove slave cylinder (2x14mm bolts) and clamp the piston fully into the cylinder using a G-Clamp or some mad finger strength, then hold the cylinder as high as possible with the bleeder pointing straight up
Step 6. Loosen bleeder nipple right off (8mm or 10mm ring spanner?) and get assistant to pump the pedal a couple times through the full length of its stroke, this must be done by hand as the pedal will not return on its own. 5 or 6 pumps usually gets new fluid through all the lines
Step 7. Tighten bleeder and reinstall slave being carefull not to let the piston fall out
Step 8. Gently pump the clutch a couple times by hand untill it becomes firm and returns by itself (this fills the slave with fluid)
Step 9. Test the pedal a few times before you reinstall all that crap, if your clutch is disengaging nicely you should be able to select all gears with the pedal depressed and should feel good, also should be able to roll the car with the pedal depressed in gear, if not, go back to step 1
Step 10. Reinstall intercooler and all other crap, ensure fluid is at the max mark in the master cylinder, go for test drive.
And for gods sake dont let the master cylinder run dry at any point.
p.s dont try using a speed bleeder or you will spray brake fluid all over your nice clean engine
Probably needs bleeding. Mine used to do it.
As far as im aware theres no return spring, im pretty sure there is a spring between the fork and engine that keeps the clutch fork in a happy place tho to prevent pedal knock off....which i lost doing my conversion
midway through procedure now - will add Step 3a: Remove starter (1x 15mm bolt in top and 1x 15mm nut at bottom)
nearly impossible to get at slave nuts otherwise - Isolate Battery 1st!!
Guest boostcut
why dont you just get a homie to help you pressure bleed the system and leave the slave cylinder in place? 10 times easier... not to mention cleaner and quicker
There is a spring on the pedal it works as an assist ( not a return type set up )
Most likely your issue is that your pedal height and free playwill need adjusting :)
Also no need to remove slave cyl when bleeding clutch
after pumping the fluid thru, finish with pushing the slave cyl piston fully back before you close the bleeder nipple
  • 6 years later...
